Squeeky Rear Shock
9 replies to this topic
  • 06_450 Rider
Posted September 15, 2007 - 06:46 PM
So i was riding today on my 450, and i noticed after about 20 minutes of riding my rear shock started squeaking when i would sit on it. I was wondering what i could do to the shock to get rid of this? Maybe oil it? Help would be appreciated. Thanks
  • KJ790
Posted September 15, 2007 - 08:34 PM
If you haven't greased your links recently, that is your problem. If that is the case then you have some work ahead of you replacing all of the bearings.
  • Dirtbiker05
Posted September 16, 2007 - 07:48 AM
agreed. when i picked up my 08 i greased the linkage and wheels and swingarm rite away. not a whole lot of grease in there. definitely gonna want to check it out.
Posted September 16, 2007 - 10:09 AM
Isolate the exact source of the noise first. Have someone work the suspension while you probe for the noise with a hose to your ear.
It's true, even a new bike should be greased, but at 20 hours, I wouldn't hit the panic button just yet.
  • Polar_Bus
Posted September 16, 2007 - 10:32 AM
Spray a little WD40 on the rubber anti-bottom cushion on the shock shaft. They have been known to squeek sometimes.
Posted September 16, 2007 - 12:23 PM
I'd avoid that. WD40 will gather dirt, which may compromise the shock seal.
  • 06_450 Rider
Posted September 16, 2007 - 03:58 PM
Thanks for all the help guys:thumbsup:
  • greentyler
Posted September 16, 2007 - 08:41 PM
completely completely agree!
wd40 is waaaaaaaaay overused IMO.
  • Polar_Bus
Posted September 17, 2007 - 09:40 AM
KX's are WELL known for squeeking shaft bushings. Been shooting WD40 on the shafts for the past 20 years, never had a seal fail. Dirt gets packed around the seal reguardless of using WD40 or not. I use WD 40 everywhere on my bikes to keep away rust, and displace moisture.....
Posted September 17, 2007 - 10:19 AM
Be that as it may, a "dry" silicon spray would be a better choice. WD40 is a fabulous moisture dispersant (what it was meant to do), but is not a particularly good lubricant, and is a really substandard rust inhibitor.
  • Hot  30 replies
  • Hot  38 replies
  • On January 15, 2017
  • 0 replies
