1995 XR600 Need jetting recommendation
5 replies to this topic
  • ledrain
Posted September 14, 2007 - 10:16 AM
A friend of mine has installed an 11:1 high compression piston, stage I cam, and FMF Q slip-on on his 1995 XR600R with a baja kit.
He is running stock jetting. The bike runs like crap...misfire, bogging, won't run clean or rev out.
Does anyone have any suggestions for jetting?
Thanks,
ledrain
  • cleonard
Posted September 14, 2007 - 11:00 AM
A friend of mine has installed a high compression piston and FMF Q slip-on on his 1995 XR600R with a baja kit.
Thanks,
ledrain
It is lean with the stock jetting.
I think that I have a 68S pilot, a 158 main, and the needle in the 3rd position. However, my bike is more or less stock. I would start there, or even start with a 160 main. See how it works and go from there.
  • martinfan30
Posted September 14, 2007 - 12:42 PM
try cleonards jetting recomendation. definately way too lean for that setup.
  • ledrain
Posted September 14, 2007 - 02:25 PM
Thanks,
ledrain
Anyone else have a suggestion? Anyone else running a setup like this?
  • Beerad
Posted September 14, 2007 - 02:38 PM
Stock jetting is waaaaay to lean for anything but a bone stock 600. With that set up, i would go with the 68 pilot as Cleonard recommends with at least a 160 to 165 main.
  • Kawabuggy
Posted September 14, 2007 - 05:39 PM
Look at my signature.. I have a very similar set up. I am running a 68S, and just switched to a 160 main.. Yes, I know I need to update my signature. This bike is a screamer with this jetting!
