Yzf 426 crank sprocket. Do I have problem or not. Pics.
15 replies to this topic
  • kubamtx
Posted September 13, 2007 - 01:00 PM
Hello
The continuation of my thread but now I only need your opinion. I don't have much experience with 426 so please tell me. Is this crank sprocket good or bad and what do you think how many hours does it have.
http://www3.speedysh.../21127413/1.jpg
  • kubamtx
Posted September 13, 2007 - 01:05 PM
I now that I have to change the chain. It started wearing teeth heads so I'll instal new one tomorrow.
  • Butta
Posted September 13, 2007 - 01:18 PM
Would love to help, but can't see the pix....anyone else??
  • kubamtx
Posted September 13, 2007 - 01:27 PM
I don't know why it heppens that you can't see the pics and I see them directly in the thread...hmm now you are able to click the link so it should work now at least in two ways
  • WB450
Posted September 13, 2007 - 01:47 PM
Negitive, no worky.
  • kubamtx
Posted September 13, 2007 - 01:57 PM
it drives me crazy...
you have to use the link and then click "1" to see the picture. If it doesn't work I don't know what is wrong.
Try this :
http://www.speedysha.../690254716.html
  • stroker yz426
Posted September 13, 2007 - 02:03 PM
it does look like it has some wear....the sprocket in my 00 looks just like that....but i fried my rod bearing big end and the woodriff key has been moving in its slot on the crank so i have to replace the left crank half:foul: as for your i would say you could probally just get away with a new chain if yours is bad....
  • stroker yz426
Posted September 13, 2007 - 02:05 PM
but if you need info just wait for "grayracer513" hes a walking yz "encyclopediabriyamaica" hell know if your shows signs of too much wear and hell probally post a response to this as well...he keeps his eyes open for us yz guys...like a big bro of sorts ...it gets costly to replace that half of the crank...and its a lenghty process too...
Posted September 13, 2007 - 02:12 PM
Sprocket looks fine to me. :thumbsup:
  • USED YZ426F
Posted September 13, 2007 - 02:23 PM
Hello
The sprocket looks a little worn in the picture, but I don't think that is needs to be replaced. Can you feel any ridges along the teeth with your fingers? If not, then you should be good to go on the sprocket.
  • stroker yz426
Posted September 13, 2007 - 02:28 PM
well its good that it doesnt need to be replaced...replacing the left half of the crank is costly
Posted September 13, 2007 - 02:36 PM
You can see "little ridges", but not enough to matter.
  • CaptainKnobby
Posted September 13, 2007 - 05:03 PM
IMO it looks ok! and doesnt seem to be worn any,the chain also looks to be in good condition. I have a 06 yz450f with 47 hours on it and the only thing I have done to it is change the oil (amsoil MCF 10w-40w) and clean the filter after every ride (No-Toil filter and use the No-Toil oil,cleaner and grease) The bike runs great!
  • 642MX
Posted September 13, 2007 - 06:56 PM
I agree. My sprocket looks about the same.
  • kubamtx
Posted September 13, 2007 - 11:52 PM
Thanks for answers. Now I'm happy to change the chain only. The chain is tight but I don't know when it has been changed so I'll change it. Maybe the noise'll go away.
Grayracer513 do you remember my shavings from previous post?
I found another one in magneto and now I now for 100% that it was one one tooth from locing washer on the clutch hub.
As I found everythink in magneto and nothing in oil and filter I think that everything else is ok.
Posted September 14, 2007 - 05:48 AM
As long as you believe you know the source of the fragments, and those parts are in good shape now, you can run it if you feel comfortable with it.
  • Hot  113 replies
  • Hot  50 replies
  • 0 replies
  • 9 replies
