Chain Question
8 replies to this topic
  • brightman
Posted September 12, 2007 - 03:07 PM
im sure this has been covered, so...the final verdict...650L,all the mods without going in the motor,,do any of you guys use a clip style masterlink or am i just paranoid.want to get TATtrail prepared,and i value your experience. thanks.
  • cleonard
Posted September 12, 2007 - 03:25 PM
On my 600, I've never had a problem. There are three kinds of chains. The old style non o-ring chain. The master link just slips on and is held by the clip. Never used this kind. All the ringed chains that I have used were press fit. It took a LOT of pressure to get the side plate on. They have a clip too, but I don't think it does much. One time when replacing this type of chain I found the clip missing. It may have been gone for a year. The third type is the true riveted type. This requires a special tool for installation, and should never come undone.
  • LeadDoggy
Posted September 13, 2007 - 05:20 AM
Clip type is all I ever used. Never had any problems....
  • Denn10
Posted September 13, 2007 - 05:46 AM
same here always used clip masters.
  • heavyhitter
Posted September 13, 2007 - 06:12 AM
Ive always used clips and never had an issue I been riding for 22 years. I had a buddy lose a clip but the chain stayed on and he only knew it was off from lubing the chain, dunno how long it was off.
I just got a new chain and went with a clip, they work great :thumbsup:
  • XR650L_Dave
Posted September 13, 2007 - 07:54 AM
The Oring chains I've gotten, the instructions say to make sure the plate is tight against the back of the clip.
If you press the plate on a bit too far, I guess there could be a small gap behind the clip, making it easier for the clip to come free.
I press the plate on a little at a time, just enough to get the clip on, then after the clip is fully seated I use the chain breaker to pull the plate out against the clip to make sure its tight.
Dave
  • YetiX
Posted September 13, 2007 - 12:32 PM
Clip master here too.
  • brightman
Posted September 14, 2007 - 12:36 PM
thanks,i got a new gold kmc i think it is,just wondeing if there was any horror stories about the clip style.you guys have eased my mind:thumbsup:
  • Denn10
Posted September 14, 2007 - 12:54 PM
http://www.kneedragg.../masterlink.jpg
Just make sure you clock it right, have the end of the clip, the open ends, pointed towards the right if its on the top. Know what im saying, that way when it goes through the chain guide the ends cant accidently grab and knock it off. Thats what ive always done
