how many inches should i cut and make them?
pvc fork spacers, what size are you guys using?
Started by deputyperk, Sep 12 2007 05:27 AM
5 replies to this topic
Posted 12 September 2007 - 06:47 AM
Take out everything but the spring and put in the pvc pipe. Mark where the pvc sticks out of the forks and add to that how much preload you want. I think some add 1/8" or a little bit more. I was going to do this and add like 3/8". I'm not sure about this so I would get another opinion.
Posted 12 September 2007 - 08:20 AM
All you have to do is take the caps off and add spacers to whats already there and button it up.When I did mine I cut a set at 15, 20, and 25MM. then try them out and youll find that you dont need very much for most riding, just keep in mind that this is not for big junps just for better handleing. The dr650 jumps like a concrete block with wheels anyway:ride: (What I would give to have some rebound dampning on the rear)
