WR450 How many km's you doing before a top-end rebuild?
11 replies to this topic
  • dazzabb
Posted September 12, 2007 - 12:31 AM
Guy's,
I'm curious to know how many km's I should be looking at before needing to change the piston / rings on an 05 WR450 used for trail riding?
Had to rebuild the :thumbsup: after a main bearing failure and have a new cylinder /piston/ rings so now being extra cautious with the upkeep.
Cheers
  • dazzabb
Posted September 13, 2007 - 08:22 PM
So nobody out there has done a top end rebuild on their WR450?!!!!
  • sidewinder2
Posted September 14, 2007 - 12:48 PM
Not yet, But mines an 06 with 41 hours.:thumbsup:
  • dr x
Posted September 14, 2007 - 02:28 PM
The manual says inspect the top end every 1000 km's
  • ckulzer
Posted September 24, 2007 - 06:49 AM
I did valves, springs, cam chain, piston, rings. etc. after 132 hours of racing/trail riding.
The valves were starting to mushroom and all other parts looked worn. It was time.....
These bikes are not like a TT500. They will not last forever.
  • face_plant
Posted September 24, 2007 - 11:58 AM
9000 miles and she is making "a little noise" P
parked til i can adjust the valves
no performance problems just noise 1st kick or 1 push of the button and off i go
  • JSanfilippo
Posted September 24, 2007 - 01:08 PM
What was the maintenence schedule like? Oil changes? Air filter cleanings? Valve clearance inspection?
  • w00dsRider
Posted September 25, 2007 - 04:52 AM
Good question! I know of a WR400 whose top end has never seen the light of day and has had only one oil change in the last two years! Not mine! I have 2000 miles on mine (06WR450) with no noise at all, but I change my oil after every other ride, no racing.
A buddy of mine has an 07WR450 that has around 1000 miles on it and it has developed a "tick". Due to new engine design?
  • JSanfilippo
Posted September 25, 2007 - 08:16 AM
The clutch on the 07 is really noisey especially when its engaged in neutral, but a "tick" is not normal. Mine has 500 miles, valves in spec, and no tick.
Tell your bud to break out the feeler gauges:thumbsup:
  • ckulzer
Posted September 25, 2007 - 08:17 AM
Sythetic oil and new filter every 10 hours of trailriding. More often when raced.
I have 3 air filters and I rotate them based on physical inspection.
Valve clearance checked twice a year - middle intake valve tightened up slightly but within spec before the rebuild.
None of the motor parts looked like they were on the edge of failure, they just looked worn. I wanted to replace worn parts before old blue gave up the ghost. Pay now or pay later.....
  • JSanfilippo
Posted September 25, 2007 - 08:28 AM
Sounded like a healthy top end. Did you loose compression? IMHO 10 hrs. on oil is a long time on these bikes even if it is trail riding. These transmissions shear oil like no other. Usually the yamaha valves go a long time after the first adjustment unlike the honda CRFs
  • Mutu
Posted September 25, 2007 - 09:41 AM
I changed mine out for a high comp at about 4500kms I think from memory.
The piston and rings were still in great condition (although covered in carbon)!
