Valve Adjustment on my 650R with stage2 cams
3 replies to this topic
  • 2000dr650
Posted September 11, 2007 - 11:27 AM
I'm correct in assuming that the intake/exhaust lash settings are the same as stock, right? the cams are only different in duration.
  • hill5150
Posted September 11, 2007 - 01:52 PM
Assuming it's an XR 650R, I had my stage II in last year, I would call Rob at Barnumspro.com, he is very valuable info on the 6 fiddy...........
  • XR680RR
Posted September 11, 2007 - 02:26 PM
valve adjustment has to do with the expansion of the metal, do to heat. Even with a cam with more lift the adjustment is the same if the expansion of the cam is the same. Yes, the adjustment should be the same as stock. If you adjust is to loose them you will have noise and problems, to tight and once the metal expands enough the valve won't close.
  • 2000dr650
Posted September 11, 2007 - 02:27 PM
kwell ...thats what i thought:ride:
  • 9 replies
  • 22 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Honda XR650L 2016
  • 0 reviews
