Stalling - bars to the right
5 replies to this topic
  • Rocket360
Posted March 11, 2002 - 12:03 PM
All -
Had an interesting issue come up last weekend, at low speed when I turn the bars way to the right, my 99 wr400 stalls. This happened only at low speed while making a tight turn, the rpm's did not appear to kick up or fall down - the bike just died.
I am going to chase the wire for the kill switch tonight - - any other ideas or suggestions???
Thanks,
Rocket
  • jamracing
Posted March 11, 2002 - 05:37 PM
Your problem is pretty much narrowed down to the kill switch. You might also want to check the freeplay on your compression release cable
  • acarter920
Posted March 11, 2002 - 05:54 PM
Its the compression release cable... im pretty positive about that. I had the same problem. Just give it a little more slack and it will be fine. :)
  • Rocket360
Posted March 11, 2002 - 06:33 PM
Thanks for the info and ideas, I will chase both the kill switch and the compression release lever and report back.
Rocket
  • TeamScream
Posted March 11, 2002 - 06:52 PM
It is definately the compression release cable, when it gets routed the wrong way it pulls and opens the valve
  • Taffy
Posted March 11, 2002 - 10:45 PM
definately the compression release. 100%, as the lads say.
with higher bars you need over 1/4" slack-but this depends on the routing of the cable of course.
Taffy
