YZ426 Gearing - Confused?
6 replies to this topic
  • maz13b
Posted September 09, 2007 - 06:14 PM
I have a '00' YZ426 (444 Bore Kit) with stock 14/49 sprockets.
Ive been reading thread after thread on 426 gearing and most seem to be running 14/52 gearing or similar... which will give you more bottom end- correct?
Now where im confused is i feel my bike runs out of legs to quickly, bottom end power is great i love it but in top gear i cant stretch it out to much.. i ride with wr450's and on the long straights i always fall back cause motor seems to be reving to high.
We ride in pine forrests on dirt trails, rocky hill climbs, etc.
So im thinking i have to go down a couple teeth in the rear to get more top end or maybe up one tooth on the front- Does this sound right?
Keeping in mind i dont want to loose my bottom end :thumbsup: just want a little more up top.
Cheers
  • kenr74
Posted September 09, 2007 - 06:31 PM
What I have heard is that 3 teeth in the back is similar to 1 in the front. I'm not sure what my 426 is geared at but I sure wouldn't want it to be any faster.
  • Birdy426
Posted September 09, 2007 - 06:54 PM
You are correct...14/52 will give you more bottom and less top.
When I installed the big bore kit on my 01 WR, I found that there was actually too much bottom end...if I just crack the throttle on single track, the back end would bust loose. Granted it's a WR and the internal ratios are different.
Anyway, I went up one tooth on the countershaft sprocket and it made all of the ratios feel a lot more "right" It has significantly more top end than my riding partner's YZ426's
If you are starting with 14/49 gearing, that would be like going down 4 teeth on the rear sprocket.
  • maz13b
Posted September 09, 2007 - 07:16 PM
Yes you are correct, with the big bore kit traction down low is much worse.. i think i might try the 15/49.. do you think it will still be agressive down low?
Thanks
  • gsk1968
Posted September 09, 2007 - 07:31 PM
Kinda like "can I have my cake and eat it too?" Take the number of teeth on the back sprocket and divide by the number of the front.
Xample 48 div by 14 = 3.43 good top end or 52 div by 13 = 4.00 good bottom end. If you want a happy medium try 14 and 52 = 3.71 and so on.
the front turns 3.71 times to 1 turn of the back, this is your gear ratio.
the higher the ratio the lower the gear = bottom end torq
the lower the ratio the higher the gear = top end speed
This is why the trick bikes have monster spockets on the back...
Just dont try a 12 on front of 01 426, even a narrow(cheap) chain scrubs the case.Requires spacers which offset chain which = more wear. god luck
Posted September 09, 2007 - 07:50 PM
That's because most of the threads on the subject start out with a question about gearing for the woods. If the question went to desert gearing, or civilizing a 444, the responses would be different.
And yes, 3 at the rear is very close to 1 at the front when you mention gearing in this range.
  • maz13b
Posted September 09, 2007 - 08:20 PM
No Probs. Thanks all
Il try a 15/49 as mentioned, just hope it dosnt loose too much botom end.
If it does il prob then change to a 15/50 or 15/51.
Cheers
  • 10 replies
  • Hot  28 replies
  • On January 15, 2017
  • Hot  113 replies
