2001 426 primary drive gear damage
2 replies to this topic
  • jed00011
Posted September 09, 2007 - 04:07 PM
Well, like many others I found the engine noise to be a loose gear that interfaces with primary drive gear on the clutch basket. Problem is gear on the clutch basket is broken. Is there any where you can get just the gear and not the entire basket assembly from Yamaha?
At least I killed the engine before she completely exploded. Any help would be appreciated.
  • Birdy426
Posted September 09, 2007 - 04:09 PM
e-bay...good luck. Did the primary drive gear dork up the splines on the crank as well?
  • jed00011
Posted September 10, 2007 - 01:15 PM
No, the gear on the crank looks ok, but gear on the clutch has a 3/8 inch piece missing.
