!!please Help!!
7 replies to this topic
  • 426 boy
Posted September 07, 2007 - 11:34 AM
My bikes (2002 YZ426F) way over filled wiv oil is there an over flow plug any were must know withen a couple of hours please.:thumbsup:
  • Serenity Now
Posted September 07, 2007 - 11:39 AM
Just loosen the drain bolt on the bottom very slightly until oil comes out then close it right back. If you accidentally drop it just get it back in there asap before all the oil runs out and then check the level and go ride. There is no overflow check bolt like on RMZ's.
  • Jaycycle
Posted September 07, 2007 - 11:40 AM
My bikes (2002 YZ426F) way over filled wiv oil is there an over flow plug any were must know withen a couple of hours please.:ride:
Did you over fill it or was it already over filled? If you wayy over filled it (unfortunately because its new oil) I would drain it then refill to proper level. :thumbsup: There is a breather on top of the head that should spew oil if you overfilled it to much. A guy once told me it is better to be low on oil then to have to much.
  • Butta
Posted September 07, 2007 - 06:09 PM
I would agree with this suggestion. Oil's cheap, and it doesn't take long. Better to do it right than to wish you had........
  • Birdy426
Posted September 07, 2007 - 10:25 PM
Man, that's great! I have a list of my favorite quotes onthe white board at work (A picture is worth a thousand words...and hardware is worth a thousand pictures; Flexibility is the key to indecission; No plan survives first contact with the enemy etc.) and this one's going up there Monday morning!
  • 00 Kracker 00
Posted September 08, 2007 - 03:12 AM
Did you let the bike warm up?
Shut the engine off, then let the oil settle for about 10min in the engine, then pull the dipstick wipe it off, then stick it back into the frame but dont screw the dip stick in, just plug the hole with the dip stick then pull it out and check your level.
If your checking the oil with the engine cold, then your getting an innacurate reading .
Posted September 08, 2007 - 08:44 AM
Man, that's (one of) of my favorite quotes
The variation of that that I know is "Better to do it right than to do it over."
  • Butta
Posted September 09, 2007 - 09:33 AM
Works for me!!!
Another one of my favorites:
Nobody makes it through life alive.......
  • Hot  113 replies
  • On January 15, 2017
  • Hot  47 replies
