Clutch lever pull on my 99 YZ400F
9 replies to this topic
  • PatrickM
Posted September 07, 2007 - 02:11 AM
I had my clutch replaced about three rides ago and I had the clutch adjusted but after riding my bike a couple of times, The clutch seems to be getting tighter and tighter.
I dropped my bike once since everything was adjusted and my clutch lever was bent to the point of cracking....
Now my clutch lever is super tight. its almost to the point that I cant hold it for very long after a couple of hours on my bike.
Now...I dont know if my cable should be adjusted or replaced
if the cable needs to be adjusted.....Do i adjust it on the engine side or the lever side????
If the cable needs to be replaced....is it easy to do???
Thanks for the help TT'ers!!!!
Patrick M.
  • Yz400Flyer
Posted September 07, 2007 - 07:26 AM
Patrick M.
I have the excat same problem, on the excat same bike, so hopefully someone can help us out.
  • PatrickM
Posted September 07, 2007 - 04:39 PM
Anybody have ideas??????
Patrick M.
  • Markopolo400
Posted September 07, 2007 - 05:12 PM
Play with the adjusters on the clutch cable to loosen up the lever.
  • PatrickM
Posted September 07, 2007 - 06:46 PM
should i adjust at the lever or at the engine side of the cable????
Patrick M.
  • Solo
Posted September 07, 2007 - 08:20 PM
Both! You should adjust the cable at the engine side in such a way that the lever end is at mid adjustment. This will leave you with the most adjustability on the trail.
  • yz400f_Torqer
Posted November 28, 2007 - 01:02 AM
Yeah bro my bike seems like the clutch pull is way to close.And its super tight.I cant put one finger on the clutch to rev it for a monster wheelie.Like on my last bike (2004 honda cr125):thumbsup:
Posted November 28, 2007 - 06:55 AM
If the increase in effort came immediately with the new clutch, my guess is that after market springs were used.
If the increase in effort is something that has developed since the clutch was replaced, it's probably a bad cable. They're not hard to replace.
  • klxnewguy
Posted December 07, 2007 - 11:05 AM
I would replace the cable to start, I did that and it helped, I also bought an "Easy pull" from moose racing and man that helped out a ton!! You do have to spend some time adjusting all the cables to make it work well and all should be go. As stated about they may have put on stiffer springs and that is a good thing once you get past the whole thing.
  • PatrickM
Posted December 07, 2007 - 05:23 PM
I decided to go with a new cable and ASV levers.
thanks for all of your input!!!
Patrick M.
  • Hot  47 replies
  • On January 15, 2017
  • Hot  50 replies
  • Hot  36 replies
  • Hot  113 replies
