Proper chain adjustment
2 replies to this topic
  • tp3dxf
Posted March 10, 2002 - 06:45 PM
I know this is a rookie question. But how can I tell if my chain is adjusted properly? How much slack should I have with a rider on board? I am trying to figure out if my swingarm is wearing under the chain guide because of inproper chain adjustment or just bad design. I gotta fix it soon. It's eating away at my swingarm. I just hate to have to spend a lotta time and money to fix something that shouldn't be broken. I wonder if I could warranty this.
  • skthom2320
Posted March 11, 2002 - 11:04 AM
Your chain should be adjusted with the rear wheel off the ground. The manual say to allow 1.6-2" slack when measuring directly above the rearmost chain slider bolt.
I run mine at 2".
The wear underneath the slider is from the slider moving back and forth due to a bad design. I glued old inner tube to the bottom of the slider then bent the "hat" portion of those silly washers down a little bit with a socket. Once that was done the chain slider does not move back and forth.
Later,
Steve
  • Bill
Posted March 11, 2002 - 03:18 PM
To loose is way better than to tight. If the chain is to tight, the rear hub could grenade :)
I use three fingers width at the end of the slider. Course three fingers of a good scotch ain't bad either :D
Bill
