TT'r AgoosSS was good enough to help provide some details on doing a CR type brake line swap with Ride Engineering parts HERE and the first step was to switchover to KX250 fork guards.
Since my stock guards were already cracked and brittle, I did the first step this week and it was pretty easy. There is one sticking point with regard to the factory odometer cable on the right side needing a guide/holder which isn't on the KX250. Some use zip ties, other use two left side guides, but I was able to drill the rivets off the original fork odometer clamp, trim it, drill it, and re-rivet/bolt the clamp onto the right side guide without much trouble. Very sturdy and looks nice, I really like the black guards on the green bike!
Thanks again to AgoosSS!
A picture is worth a thousand words so here it is...
