XR600 stock gas tank repair?
6 replies to this topic
  • HondaRules
Posted September 04, 2007 - 10:36 AM
For some reason in this past week my gas tank started to crack. It has a bunch of cracks around the gas cap and along the front edge on both sides of the tank. I've never seen this happen before. I ride the bike about twice a month on average and it is garage stored. Does anyone know if there is some sort of epoxy to fix this or is a new tank my only option?:thumbsup: Does anyone have their stock tank laying around that they would care to sell:ride:
  • Bunnin
Posted September 04, 2007 - 10:48 AM
I have cracked alot of tanks over the years and i have found that "JB Weld" is the best epoxy for filling in gaps escially on plastic tanks, its a really easy to use epoxy but needs a considerable amount of dry time, and is avaliable at almost any hardware store, its not just limited to plastic i have used it to seal cracked crank cases and much more, i always bring some with me when i ride since it will save your but when your 100 miles from civilization and need a fix quick,
just mix the 2 parts till it turns grey (one part is black the other is tan) and let it sit for a few hours (best if left over nite) and it becomes rock hard adn you can ride again
  • koldsimer
Posted September 04, 2007 - 01:07 PM
How long have you been running the JB-welded tank? I had a friend who did that once and it was always giving him trouble. I also heard about using plastic repair kits that are intended to repair kayaks and other similar plastics.
  • Bunnin
Posted September 04, 2007 - 02:30 PM
I had a 1981 Yamaha IT 175 that i broke the tank, right on the bottom where the fuel Valve connected and i put JB weld on it and had no problems for 3-4 years and i ended up selling it with the JB weld still on,
and does anyone know how to change your screen name i spelled mine wrong it should be Burnin and it shows as Bunnin.
  • Greco
Posted September 11, 2007 - 12:58 PM
I have a stock tank I'd be willing to sell to you if you need it. Since getting the Clarke tank hooked up, it just sits in the garage. PM me for details.
  • HondaRules
Posted September 11, 2007 - 03:29 PM
DOAH! I just bought one off of ebay last night...I'll keep this one in mind though in case the one I get isn't worthy:thumbsup:
  • XReliXR
Posted September 11, 2007 - 06:44 PM
You can either buy a plastic welding kit off of ebay or you can go to a local auto body shop that repairs plastic bumper covers. Just like anything tho it won't last for ever. Not wanting fuel all over my jewels after a bumpy ride I would just buy a new tank.
