07 450 intake valve out of spec
13 replies to this topic
  • chan470
Posted September 02, 2007 - 07:24 PM
Hey TTer's. I have a problem. Need you help.
I have approximately 30hrs on my bike. I checked the valve clearance for the first time today. All exhaust were @ .22mm and two intake were @ .12 mm. One intake was tight and out of spec. A .102 mm would not fit and a .078mm fit but was very loose. I don't have a feeler between the two measurements. I'm guessing the valve clearance @ .09mm.
Has anybody else had problems with the 07 valves being tight? Now I'm worried about the valve that was tight. I had a 426 for 5 years and the valves were never out of spec.
Should I just reshim and not worry about it. Could the valve be damaged? Can I just remove the intake cam and reshim without removing the exhaust cam since they were in spec?
So what do you think? :thumbsup:
  • todds924
Posted September 02, 2007 - 09:06 PM
In my experience with Yamahas, that is rare to hear of a valve being out of spec. I;m going to guess that its probably the middle intake valve? I would just re-shim it and not worry about it. You can re-shim it by rolling the motor over to Top Dead center, retract your cam chain tensioner and remove the intake cam holder. Just push the cam forward and remove the bucket of the one you need to change.
Posted September 02, 2007 - 09:28 PM
This happens occasionally, and it's normally due to the valve settling into the slightly less than perfect seat. The loss of clearance is usually small, and stops as soon as the seat wears into a match with the valve.
In your case, shim as needed to get into spec, then recheck in 10-15 hours. If the clearance has remained as you set it, then the problem you have is just a new valve seat settling, and you'll be OK.
  • chan470
Posted September 03, 2007 - 06:18 AM
grayracer- My shim pads do not have numbers on them. How do I know what shim to install? Have you ever seen pads without the numbers on them?
I buy yamaha's so I do not have to deal with stuff like this!!
Posted September 03, 2007 - 06:30 AM
The number may have faded, or just not have been very dark. Try taking it out into the sunlight to se if you can read it.
Failing that, if you don't own a micrometer, take the shim to your dealer and have their service department mike it for you.
  • chan470
Posted September 03, 2007 - 06:53 AM
I used a flashlight NO number. I'll try sunlight but I'm almost positive the number is gone. I also noticed that the cam tensioner what missing a washer. I know that is not a big deal but I'm feeling like I bought a lemon.
The bike is great on the track (the best I have owned) but I expect more from Yamaha than missing washers and out of spec valves. Just having a rant.
Thanks for the help.
  • todds924
Posted September 03, 2007 - 11:22 AM
Sometimes depending on which way the shim is installed, the numbers will wear off. A set of digital calipers is a great investment. Are you sure the cam chain adjuster washer didin't stick to the bolt? Never seen one without a washer....unless someones already had that bolt out and lost it.
  • chan470
Posted September 03, 2007 - 01:34 PM
yes I'm sure the washer is not installed. This is my first break down of the bike so I know I have not removed the bolt. I don't know about the dealership but why would they remove the cam chain adjuster?
A buddy is a tool and die machinist. He is going to mic it tomorrow.
  • todds924
Posted September 03, 2007 - 05:41 PM
The washer is a copper washer. If you bought the bike new it should have been there. Never seen one come from the factory without one. Never!! Now maybe one of the mechanics at the dealership lost one and "borrowed" one from your bike.
  • chan470
Posted September 06, 2007 - 05:37 AM
I reshimmed the valve and now it is within spec. When I started the bike the engine noise seems louder. The engine has always been loud but it seems louder now. Can a new shim pad make the engine "knock"? I took it part and doubled checked valve clearances and timing. All was correct.
I went to practice lastnight and the noise is driving me crazy. A friend has the same bike so we started them up and my engine noise was louder. I would describe his as a "tick" and mine as a "knock". The noise was louder at idle and on the right side of bike. Not "clutch" noise. I know that sound and this is different.
When I checked the timing the dots on both cams where lined up with the head as stated in the manual but the exhaust cam seemed slightly higher.
I also noticed one more thing when I start the bike it back fired a couple of times when I was kicking it over. I don't remember it doing it before. But the bike was easier to start.
Sorry for the long post. I have double race weekend coming up and I'm freaking out! :ride: Any ideas or advice will be greatly appreciated. :thumbsup:
Posted September 06, 2007 - 05:47 AM
I
Because of the length of the chain in this engine, the cams will rarely line up perfectly. The question is, if you moved the cam one tooth either way, would it line up better, or worse?
It is possible, if unlikely, that you have a loose primary gear or clutch boss retaining nut. If you're that concerned by the noise, you should probably pull the right side open and check things out.
  • kyle450rider
Posted September 06, 2007 - 06:03 AM
Had to shimm mine at the 8 hour mark on a 2007. Your situation is the exact thing that happened to me. All the people on here that were complaining about engine noise. Well i had none before reshimming. After shimming its loud but i've put 10 hours on it since with no problems. I think its just a yamaha thing! I hear a loud tick but no knocking sound. I can hear it riding but just when i let off the gas into a corner.
  • chan470
Posted September 06, 2007 - 06:05 AM
the timing marks on camshaft gears or the cam lobes?
Posted September 06, 2007 - 07:39 AM
Gears. There are no marks on the cam lobes.
  • Hot  36 replies
  • Hot  38 replies
  • 5 replies
  • Hot  30 replies
