Question on gearing...
1 reply to this topic
  • Just_a_trail_rider
Posted September 02, 2007 - 01:18 PM
I have an 05 wr450, stock gearing, fmf pipe, etc...
I ride in enduros, hare n hounds, etc... in the socal desert. I also do dual sport rides, but mostly technical stuff.
I often find myself riding in high rpm second or low rpm third gear. I am always clicking between 2nd and 3rd to try to keep the engine spinning at rpm's that will still give me some accelleration. But I end up shifting too much.
If I go to a 13 tooth counter sprocket, I am thinking that I will have a little more pull when in low rpm third and can acclerate better. This way I can lug it more in third and then accelerate when I have to.
But... will it make 1st gear worthless for me? What will it do to my overall top end (that I rarely use anyways). What will be the effect on gas mileage? Thanks.
  • dazzabb
Posted September 02, 2007 - 05:20 PM
I fit a 13 tooth front 2 weeks ago to my 05 WR450.
Now running 13/50 and I love it.
You will notice the improvement in that 3rd can be used more often and yes it will reduce the amount of shifting if you were using 2/3 gear often.
On the downside 1st is pretty low but still usable in the REALLY tight and knarly stuff.
Fuel consumption will increase (as if it could get any worse!)
I like the fact it will crawl down the hills a wee bit slowler as well with reduced gearing.
