Ricky Stator or Baja Design Stator?
6 replies to this topic
  • glabudde
Posted September 02, 2007 - 12:38 PM
Is replacing the stock stator as easy as unbolting the old one and installing the new one? Is there a need for other components with the increased output?
Currently running with a BD dual sport kit. The BD site has some very detailed instructions and it looks more complicated that just bolting the new one in.
Any thoughts or comments?
  • xr650rkyle
Posted September 02, 2007 - 01:18 PM
yes it is really pretty easy, I did a ricky stator change and it cam with complete directions. Don't forget to drain the oil first.
  • XR4DEZ
Posted September 02, 2007 - 02:38 PM
Why drain the oil?
  • glabudde
Posted September 02, 2007 - 03:28 PM
Does your bike have a dual sport kit, and if not would that make it more complicated? I understand that RS will send a new stator without the need to send mine in which means less down time.
  • exaresix
You do need other components. If you go all AC you need a heavy duty AC regulator to handle all 200+ watts. If you split the output 100/100, you will need a second AC regulator. If you split the output 100AC/100DC you will need a regulator/rectifier as well as a battery (this is supposedly what most dual sport kits do). This set-up becomes slightly more complex because you also need "relays" if you want to turn the headlight (running on the AC circuit) on or off and use the high/low beam. If you want to have a horn, it must be connected to a DC circuit. Finally, if you want to go all DC you will need to run everything through a regulator/rectifier, and the only unit I am familiar with (the Tympanium) will handle a max of 200 watts (BD unit cranks out 250 watts, Ricky Stator 200 watts).
Ultimately, it is the decision-making that is the hardest part.
  • resslera
Posted September 02, 2007 - 03:53 PM
I originally put the BD dual sport kit on. Not liking the weak headlight I did the ricky stator 200 watt stator and used the directions from the Baja Site. All I had to buy extra was a relay for the headlight and a 100 watt bulb.
You sure don't need to drain the oil when replacing the stator. No way no how.
  • exaresix
Posted September 02, 2007 - 04:03 PM
Yep, BD recommends a split AC/DC system in which you need to add relays for the headlight.
  • 4 replies
  • Hot  60 replies
  • Hot  35 replies
  • Hot  186 replies
Honda XR650L 2017
  • 0 reviews
