How to use flywheel puller
5 replies to this topic
  • frankycottonrow
Posted September 02, 2007 - 09:37 AM
I don't know if I am doing something wrong or what but I cannot get the flywheel to budge. I've got the flywheel puller onto the flywheel and a wrench on the inner nut holding against the top of the foot peg and I am going down on the outer nut and nothing moves. Am I doing something wrong?? How does it work, b/c I don't want to screw anything up. 07 yz450 thanks
  • WB450
Posted September 02, 2007 - 09:46 AM
Inner nut or crank?
Did you remove the nut holding the flywheel on?
  • frankycottonrow
Posted September 02, 2007 - 09:50 AM
Yeah, I removed it no problem. I just cannot get the flywheel to "pull" off and I am pretty sure I am doing it right
  • WB450
Posted September 02, 2007 - 09:53 AM
I did my 07 two weeks ago, it popped right off. Maybe apply some pressure with the puller, and give it tap on the end of the puller bolt.
  • treygreen
Posted September 03, 2007 - 06:07 AM
loosen the crank protector out a little ways the inside of the puller is making contact with the crank protector not allowing it to move. If I remember thats what it was with me.
Posted September 03, 2007 - 06:40 AM
There you go. Once you have a fair amount of pressure against the screw, strike the end of the screw with a hammer. Don't hit it as hard as you can, but give it a good, sharp blow or two. It should pop free in 3 hits or less.
