03 yz450 not starting for first time
9 replies to this topic
  • dirtman22
Posted September 01, 2007 - 08:44 PM
hey guys i went out to start my 03 yz450 today and it never started. This was very different from normal where it starts within the first 2 kicks every time. I have yet to replace my spark plug since owning it, but ive heard its a pain in the but so i dont want to do that untill i know its the plug for sure.
Some things the bike was doin:
1) After kicking several times smelled gas from exhaust
2) Really loud backfire on a few kicks
and cant think of anything else right now
  • Ga426owner
Posted September 02, 2007 - 05:22 AM
Sounds fuel related or carb issue but could also be valve adjustment time
  • go_speed
Posted September 02, 2007 - 05:26 AM
my 426 did it friday. put new plug in. second kick fired right up
  • dirtman22
Posted September 02, 2007 - 05:42 AM
yea it sounds like the bike is choking trying to start it not getting fuel or air but then when i kick gas fumes come out of the exhaust. Could this have anything to do with the fuel screw and where its set.
  • Quack
Posted September 02, 2007 - 03:05 PM
Replace the plug, it will prolly start then. Yes it is a bugger to do, but really it isnt all that hard if you are at home and have a few tools. I had to change mine at a track and didnt have tools. Still only took like 15 min, and that was my first time.
  • dirtman22
Posted September 02, 2007 - 06:12 PM
ok ill replace the plug, have to wait till tuesday to pick one up, and ill see how that works. I tried to start it again today and it actually started for about 1 sec and then died with a really loud backfire, does that hopefully sound spark plug related??
  • kevin204
Posted September 02, 2007 - 06:27 PM
Probably, I had a Yamaha 250F that was doing basically the same thing, and putting in a new plug solved it.
  • 695
Posted September 03, 2007 - 04:42 AM
What is the LAST thing you did to it ? change air filter,oil or anything double check you work there first. Have never changed the plug !!!!! well regardless it needs a plug.
  • dirtman22
Posted September 03, 2007 - 01:30 PM
haha no ive never changed the plug, i should have said it differently though, Its an 03 but it was stored and never ridden until last winter so it hasnt been a year yet on the plug, but it would have probably been time for a change anyways. Im just hoping the spark plug is the problem.
  • Quack
Posted September 03, 2007 - 02:55 PM
Mine acted just like yours, I replaced the pplug kicked it twice, and all was good.
  • 0 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
  • Hot  79 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • 9 replies
