Painting 05 WR450 Frame
16 replies to this topic
  • Motoequip
Posted September 01, 2007 - 09:30 AM
Has anyone tried touching up their frame on a WR? If so what did you guys use? I bought some paint from an ebayer that you brush on, but it's not looking so good. Maybee after a few coats along with sanding then polishing it will look ok. Here are a few pics. of what I'm trying to accomplish.
http://i12.photobuck...gu/DSC00778.jpg
http://i12.photobuck...gu/DSC00772.jpg
http://i12.photobuck...gu/DSC00755.jpg
http://i12.photobuck...gu/DSC00653.jpg
653 and 755 are before pics.
772 and 778 are after pics.
  • BajaFool
Posted September 01, 2007 - 10:58 AM
PJ1 Coatings sells OEM frame paint in aerosol cans. See your Yamaha dealer or any motorcycle accessory shop. Remember to apply clearcoat after you paint your frame.
  • JSanfilippo
Posted September 01, 2007 - 11:52 AM
lookin good. 100% better than before! Have you ever thought of investing in some devol, GTY-R, or works connection frame guards?
  • Solo
Posted September 01, 2007 - 02:41 PM
If I ever worry about mine I'll just send it out for powder coating. I might even try a different color. :thumbsup:
  • 450 Dude
Posted September 01, 2007 - 03:52 PM
Yeah i'm thinking powder coating might be a better decision.
  • AnthonyB
Posted September 02, 2007 - 01:51 AM
You left the primer off :thumbsup:
  • Just_a_trail_rider
Posted September 02, 2007 - 12:48 PM
I have the frame guards. But it doesn't help with the part where the upper part of your boots rub. I only wish the frame guards came all the way up that mid-frame tube.
  • trailordune
Posted September 02, 2007 - 07:48 PM
Electrical tape works great above the frame guards. :thumbsup:
  • xrmarty
Posted September 02, 2007 - 09:10 PM
Looks good. Keeping the frame looking good makes the whole bike look really good:thumbsup:
It'll still wear off, may be not as fast, but it sure will eventually. The clutch and magneto covers on my '07 are already showing significant wear.
  • Bamster
Posted September 03, 2007 - 05:59 AM
Why bother?
It ain't gonna last.
  • Gadsen
Posted September 03, 2007 - 04:32 PM
Dittos on the clear coat. It will look like fecal matter if you dont do the clear. I have used the PJ1 blue and clear for a perfect match. This was for my old WR426F. But be warned, PJ1 paint alwasy clogs up the spray nozzles!
  • Motoequip
Posted September 03, 2007 - 07:29 PM
Thanks for all the replies. And yes I ordered the devol guards already. I bought this bike used and wanted to make it look new again before I crashed on it...:bonk: :eek: :ride: I also added a couple more coats and wet sanded, it's looking a little better now.... Nice to see it's not just my bike that the paint is coming off...:thumbsup:
  • trailordune
Posted September 04, 2007 - 01:51 PM
After spraying always turn the can upside down and spray until no more paint comes out. This works for any brand of paint and the nozzle will stay clean.:thumbsup:
  • new2blu
Posted September 04, 2007 - 06:16 PM
Contact ColorRite forthe correct color.
http://www.colorrite...ar.php?typeID=2
  • Gadsen
Posted September 04, 2007 - 08:14 PM
No, I meant is plugs up while I'm spraying. I've had every can of PJ1 do this to me. I clean it, sprays for about 5 seconds, clean it, sprays for about 5 seconds.... Its like the pain it too thick for the nozzle. I used a WD40 nozzle, but it goes on quick, so I must be careful.
  • BajaFool
Posted September 04, 2007 - 08:29 PM
I just checked the blue Yamaha frame paint from Colorrite in an aerosol can--- $33.95. A little pricey!!!! PJ1 is MUCH cheaper.
  • johunter666
Posted September 09, 2007 - 09:20 PM
To keep the paint from wearing off, get ahold of some 3M clear vinyl tape. This tape is also used to protect against hood chips on automobiles. I put this tape on the high wear areas of the frame and almost 3 years later --frame looks great. The tape does scuff and loose its shine, but the paint stays on the frame. When the tape starts looking real nasty, peel it off and put a fresh piece on. Much less hassle than painting. Keeps the bike looking much newer than it is.
