07 YZF450 cornering fixes???
26 replies to this topic
Posted September 04, 2007 - 04:29 PM
#21
It says "choice of height", which is the same as "choice of bar size". You decide that before you buy, or you buy another set of bar mounts later. Their bar mounts have an offset fastener at the clamp, so that they move the bars forward or back when reversed.
  • Ranger18
Posted September 05, 2007 - 07:01 AM
#22
Get rid of that stock tire, it will make a world of difference. Also make sure your sag is set. One other thing you can try is a step seat, it kind of forces you onto the tank when you slow down for the turn.
Posted September 05, 2007 - 07:18 AM
#23
... make sure your sag is set. One other thing you can try is a step seat, it kind of forces you onto the tank when you slow down for the turn.
Along those lines, get taller bars than you think you'd like, and move them a little forward. The bike is quite sensitive to rider position and small changes in setup.
  • CRF250dude26
Posted September 05, 2007 - 04:18 PM
#24
I have already rode a 06 that had fresh michelins and windam bend bars, so I think some 24mm clamps and it would be perfect.
  • yam 3
Posted September 07, 2007 - 08:09 AM
#25
Check your steering stem bearing as well these bikes are notorious for contaminated bearings.
I recently added the drd rad. lowering kit and it makes a noticible difference as well.
  • skipperlantz
Posted September 10, 2007 - 06:17 PM
#26
I have found that getting as close to the tank as possible will make this thing turn. It takes a little effort to get way foward, but it will help.
  • twenty34
Posted September 10, 2007 - 06:29 PM
#27
Agree...Getting forward with a good tire helps quite a bit. The YZ's DO require more work to get them to turn, but they will. I just wanted something that requires a little less effort when the going gets tough.
  • 0 replies
  • Hot  50 replies
  • 5 replies
  • On January 15, 2017
