Wats the main difference between the 99 WR and the 00 WR
2 replies to this topic
  • absolut
Posted March 08, 2002 - 04:58 AM
hi, guys wats the main difference between th 99 model WR and the 2000 model other then the carb?
  • Tim_in_WA
Posted March 08, 2002 - 11:01 AM
Just off the top of my head, and from memory (scary), the Y2K model got some suspension upgrades, the steering head geometry was improved (bars a little further forward in the triple clamp, and fork angle tightened up for better turning response), easier clutch pull, and I think the gas tank is a little narrower. The newer FCR carb alone was a nice improvement.
Try searching the archives because I know the differences have been discussed.
  • Taffy
Posted March 11, 2002 - 11:33 PM
the frame was shortened at the headstock by 5mm to put weight forward and aid grip. the frame was welded with a new weld for strength.
every year yam claim to have "improved the ignition" and that year i think they modified the advance to aid starting.
they may even have bumped up the output of the stator thingy.
Taffy
