Jetting With R&d Power Bowl?
3 replies to this topic
  • MX4Life
Posted August 29, 2007 - 04:29 AM
I just switched to blue after many years on a CRF450. I'm looking to clean up the bottom response on my new 07 YZ450F. I'm installing a R&D power bowl today and would like to address all the carb issues at once. All jetting and exhaust is stock. Fuel screw is 1 1/2 out. I race MX and all the tracks are at sea level. It's hot in the Northeast, 95 yesterday but most weekends are around 85-90. The R&D has the adjustable leak jet and a different spring for the AP instead of the oring fix. All advise is welcome as the Yamaha is new to me. Thanks...Doug
I tried the jetting forum without any luck.
  • Ga426owner
Posted August 29, 2007 - 05:18 AM
Doug I would pm Dean at R&D for advice and test results.
My thoughts on this is that the 07 is lean off the pilot and the mj and needs to be 1 step richer,but the R&D may need special jetting
  • swatdoc
Posted August 29, 2007 - 02:06 PM
You might consider sending your carb for mods to Zip Ty Racing. I hear they run the Powerbowl on their race bikes now, and should be very familiar with the jetting needed. They also do some other tweaks to the carb, including a new billet AP setup. My carb is there right now!
  • gtguy
Posted August 29, 2007 - 05:32 PM
I'd like to know if it works as advertised.
  • Hot  36 replies
  • Hot  38 replies
  • Hot  47 replies
