320 lb guy WR suspension questions
19 replies to this topic
  • afmracer
Posted August 28, 2007 - 08:07 PM
i have a buddy that has an 03 wr450.
he had custom fork springs made and has a really stiff shock spring to support the weight.
hes about 320 without gear.
he wants to buy an 07 wr450.
are the forks different?
hes thinking about putting the forks from the 03 onto the 07.
if the forks cant swap, are the springs the same?
thx Quinn
  • clark4131
Posted August 28, 2007 - 09:49 PM
It's all different between the bikes, he'll have to start from square one again...SC
  • GCannon
Posted August 29, 2007 - 08:20 AM
He needs to seek professional help!
  • SXP
Posted August 29, 2007 - 08:22 AM
The rear spring will swap from the 03 shock to the 07 so he can save some $$$ there. Apart from that, what SC said:prof:
  • 2006wr450f
Posted August 29, 2007 - 09:04 AM
Now about Nutrisystems for your buddy:smirk:
  • SJMC_DON
Posted August 29, 2007 - 08:54 PM
It may be possible to swap the forks if a upper / lower clamp assembly is available... the real question would be - Will the steering head and clamps off the 03' work on the 07' - my gut tells me no:excuseme:.
SXP is right, the rear spring will interchange just fine.
  • xrmarty
Posted September 02, 2007 - 10:24 PM
Probably won't work. I checked the part numbers for tripple clamps on bikebandit.com and they are different between 03 and 07.
  • Hot Rod Todd
Posted September 03, 2007 - 07:58 AM
you'd probably do better with an atv, or even a rhino, no? i'm 220lbs, but 320lbs sounds way too big for any kinda dirtbike.
  • Hardride
Posted September 03, 2007 - 07:09 PM
HHHHHMMMMMMMMMM I am 300lbs. My wr450 seems to do fine with me on it.
Mybe I need help also?
:thumbsup: :ride:
  • cltrobd
Posted September 03, 2007 - 07:47 PM
That's a pretty ignorant thing to post. I'm 6'5" and 300 lbs. I'm not overweight but large due to body building. I ride an 06 wr450 and it carries my weight just fine after a simple suspension mod. Some of us big guys enjoy trail riding as much as the next guy!
  • 2006wr450f
Posted September 13, 2007 - 06:05 PM
Will I'm willing to bet that 99% of the people out there that are 300+ pounds are not body builders but over eaters.
  • cltrobd
Posted September 13, 2007 - 06:15 PM
Bodybuilder here...you're probably right. I've even dropped to 230-235 now that I no longer lift routinely - hard to maintain that weight for long unless you eat a ton of food and keep lifting. When I started rding, I was at 300 lbs and re-sprung the 450 did just fine. Just trying to inspire big guys out there - not everyone that has an interst in off road riding is the size of a pro-mx'er. Hell, riding may even help a guy that eats too much!
  • SouthernXer
Posted September 14, 2007 - 08:10 AM
I've also beaten anorexia at 5'10" and 235lbs... My 450 still grunts along. :thumbsup:
  • Dominion
Posted September 16, 2007 - 12:02 PM
My bikes got no problem pulling me along and I weigh in at 240 lbs.... (I have abnormally large balls) They weigh a lot. heh. I actually beat quite a few people in races, quite often. :thumbsup:
  • Nostalgic
Posted September 16, 2007 - 05:48 PM
I'm 6'5" and 220. I can see my 450 laughing at me because it can handle a LOT more weight.
Screw the 4-wheeler suggestion, have fun on the bike after you get it sprung for you weight!
  • xrmarty
Posted September 17, 2007 - 07:22 AM
My neighbor is a really huge guy. He's gotta be like 300lbs or close to that. But he is a really good rider even at his weight. Gets beaten up on whoops a little, but other than that he rides great!
BTW: he rides an EXC 525 with all the suspension mods.
  • Punisher660
Posted September 19, 2007 - 08:29 PM
I'm a 6'3" 295 lbs guy and although I had to get stiffer springs, I have to wait for half of the guys I ride with - even the 195 lb MXers.
Its also fun to see the looks on some of their faces when they see a fat guy on a WR clearing some of the big doubles that they wont hit. On their CRFs and YZfs.:thumbsup:
  • postalrider
Posted September 21, 2007 - 07:19 PM
i trials ride with a guy that goes around the 300 mark and he would embarrass your as tremendiously!everyone thinks of trials as these tiny littlle spandex geeks but this guy rides expert class and is so smooth i am thinkin of adding 50lbs!
  • SouthernXer
Posted September 22, 2007 - 04:53 AM
Does this WR450F make my ass look fat??? :thumbsup:
  • bicyclebob
Posted September 24, 2007 - 07:46 PM
Anyone who wants to get out and ride REGARDLESS of size or sex should be welcome here and helped out finding the information that they are looking for.:thumbsup: Now off the soapbox. You might give Motion Pro Suspension a call or visit on the net. They can work wonders if you give them the right info.
P.S. If you and your buddy are ever in WA give me a call.
