Fuel Mixture Screw 3 Turns Out?
2 replies to this topic
  • jams229
Posted August 28, 2007 - 05:12 PM
I own a 2007 WR450. The directions from the AIS kit tell me to use the stock main jet 162 and a 48 Pilot with the mixture screw 3 turns out.
It runs great. My question is this: Should I go one up on the main or the pilot to get to the optimum of 1-2 turns out on the mixture screw?
I have always heard that if you have to turn the screw out 3 turns, you need to go one up on either the main of the pilot. Can someone please clarify this?
Thanks a lot.
  • dr x
Posted August 28, 2007 - 05:31 PM
Pilot....
  • GCannon
Posted August 29, 2007 - 08:24 AM
UP the pilot. You may also look for a vacuum leak since you have been messing around with the AIS. a vacuum leak will cause it to be lean at idle. check the system carfully before changing the pilot jet.
