(Another) dual carb question....'90 XR600
6 replies to this topic
  • Leget
Posted August 28, 2007 - 04:18 PM
Heres a little background to the problem....
I'm using a dual carb setup on what is basically a '90 XR600, the engine came from a '84 XL600. I changed the single boot on the '90 airbox with dual boots from an older model. The problem is the airbox boots are about 1/2" too short.
My question:
On the airbox boots I'm not sure if I should..
1. Make/find some sort of spacer to just fit between the carbs and boots.
2. Add a extra plate between the carbs and head to move the carbs back?
3. Modify the boot/airbox mount to move the boots 1/2" forward?
Moving the carbs back would be the easiest (I think) but I'm not sure how that would effect performance.
Thanks in advance for your help,
Michael
  • timothypg
Posted August 28, 2007 - 05:03 PM
what if you used a couple of those pod filters i think they are called. One for each carb, then ditch the airbox.
  • Frank ZX
Posted August 28, 2007 - 05:09 PM
I was reading awhile back about a guy that lenghtened his intake,and lost power.So you might not want to move your carb back.Hope this helps some.
  • crmc33
Posted August 29, 2007 - 03:49 AM
Yes shorter intake the better for power, but 1/2" rearwards will be unnoticeable (I experimented with +4" on my 675 and it only made 53HP! But it should have made more)
I used to run a XL600 with dual carb with pod filters and also had no problems, so you have a few choices it seems
  • Nummie
Posted August 29, 2007 - 04:22 AM
I had posted a reply yesterday, but it dissapeared into cyberspace!?
Anyway, there is supposed to be a spacer between the intake ports on teh head and the intake boots that connect the carb to the head. The spacer is about 1/2" thick. You can sort of see it in these pictures of my '84 XL600R.
Here's the complete rebuild of my XL600R if it would be of any help:
http://www.nbdsc.ca/...topic.php?t=274
  • plodder
Posted August 30, 2007 - 06:20 PM
Nummie - Your bike rack is Really well thought out and executed. If you ever want to get rid of it, let me know.
  • Huffa 2
Posted August 31, 2007 - 01:16 AM
Man, you really did a lot of work to that Nummie ! Looks good.
Did you keep tabs on the hours/$$ it took you for the rebuild ?
You anywhere near DCH Toyota ? I bought a Accord wagon off them a year ago or so, just curious if you right by them?
