2007 WR450 fork problem
3 replies to this topic
  • Chooch68
Posted August 28, 2007 - 03:52 PM
Anybody having a stiff ride at the beginning of the stroke? Mostly on small, sharp edged bumps. Have you fixed the problem? If so, how? I'm going up one rate in stiffness so I can back the compression down. At 210lbs without gear, I think this may be a good start.
  • JSanfilippo
Posted August 28, 2007 - 06:34 PM
My valving was kinda stiff like you're describing when it was new but whoops and rocky terrain have given it a decent workout. Its now very plush.
The rear seems spot on, time to play with the clickers in the front
  • tribalbc
Posted August 28, 2007 - 07:49 PM
I went 2 clicks out on compression and 1 in on rebound.
I think it's the rebound that really does the trick :ride:
Same with the shock. Keeps the bike from getting kicked around on rocks and square edges.
  • tribalbc
Posted August 28, 2007 - 08:24 PM
By the way I'm 200lbs without gear. I ride woods 90% of the time, race speed. If your terrain is more open you might want to stiffen up on comp.
I rarely bottom with my setup, but I'm not a big jumper.
