what is the easiest way
12 replies to this topic
  • ajnewton923
Posted August 27, 2007 - 03:09 PM
to straiten your subframe? i took a hard fall on the right side and it tagged my muffler and bent it over far enough to make it rub on the tire pretty hard.
thanks
AJ
i also tried searching and nothing really came up
  • bigwake
Posted August 27, 2007 - 03:21 PM
i had a bent sub for a kx250..i took it to my school shop class and bent it straight in a vice..it worked well..also..i bolted it up to the bike..and i held the bike firm on the stand..while my dad beat the lights out of it with a hammer..worked well..
  • dmoney1074
Posted August 27, 2007 - 03:29 PM
Subframes are pretty cheap, you might be better off looking for a used one than compramising the structual integrity off your bike and possibly putting yourself in danger. Check ebay... Just my 2 centavos
  • bigwake
Posted August 27, 2007 - 03:32 PM
true..i forgot to mention..i was watching some on ebay..and ended up just buying a straight used one for $60..plus shipping..so look at ebay
  • ncmountainman
Posted August 28, 2007 - 05:58 AM
thanks
AJ
take off the seat and rear plastic(fender,sidepanels,etc.) wedge the bike between 2 trees that are close enough together to hold the bike solid from side to side force. get a 5'-6' length of some 1 1/2" steel pipe(pipe not conduit) and force the subframe back where it belongs,make sure not to go too far! trees are a big part of redneck bodywork(causing and fixing the problem:crazy: )
  • ajnewton923
Posted August 28, 2007 - 07:25 AM
by bending it back will it make it that much weaker? it is maybe an 1-1 1/2 inch tops.
  • ncmountainman
Posted August 28, 2007 - 07:43 AM
if its kinked and/or cracked it would be but if its just bent i'd say you could get away with it once or twice(at least i have):thumbsup:
  • Ga426owner
Posted August 28, 2007 - 12:50 PM
take off the seat and rear plastic(fender,sidepanels,etc.) wedge the bike between 2 trees that are close enough together to hold the bike solid from side to side force. get a 5'-6' length of some 1 1/2" steel pipe(pipe not conduit) and force the swingarm back where it belongs,make sure not to go too far! trees are a big part of redneck bodywork(causing and fixing the problem:crazy: )
Bingo:thumbsup: :thumbsup: NCMTNMAN....where you been...man.....glad you are back!:busted:
This is exactly how to fix a bent subframe....also buy yourself a deadweight hammer at Homedepot....it works majic for smaller subframe bending adjustments...the pipe is also at homedepot and cost about 6bucks...works amazing:thumbsup:
I have seen totally pretzeled subframes fixed this way
  • StPeters21
Posted August 28, 2007 - 01:57 PM
ebay......get a new one :D
Posted August 29, 2007 - 08:41 AM
This only works in places like NC & Georgia, where the trees are that dense. We have to find alternatives here.
The principal is perfectly sound, though. :thumbsup:
  • ncmountainman
Posted August 31, 2007 - 08:30 PM
Bingo:thumbsup: :thumbsup: NCMTNMAN....where you been...man.....glad you are back!:ride:
i've been protesting an executive decision in the suspender forum,its fixed now;so back in business....oh wait a minute ,is it ok to say business without paying for sponsorship:excuseme: :bonk:
gray,
that explains everything...a state full of tree huggers with no trees to hug:p
  • Ga426owner
Posted September 01, 2007 - 05:43 AM
i've been protesting an executive decision in the suspender forum,its fixed now;so back in business....oh wait a minute ,is it ok to say business without paying for sponsorship:excuseme: :thumbsup:
gray,
yea I figured you were involved in that DJ mess.....hope it all worked itself out
Grey... I guess those cactus are a real bitch to deal with:p
Posted September 01, 2007 - 08:56 AM
It's not that there aren't any, it's just that either the huggers won't let anyone take a motorcycle near them, or they're far enough apart to ride between without cutting one down.
  • Hot  113 replies
  • 9 replies
  • 10 replies
