DRZ 400 mods
29 replies to this topic
  • Tennessee_Thumper
Posted 21 March 2000 - 11:37 PM
What mods have you guys made so far with the drz?Mines still stock and im considering a pipe,but I do love the quietness of the stock pipe.The only complaint I have on the bike is its to weak in first gear for steep hills.Other than that the bike is a winner.
  • Bryan
Posted 22 March 2000 - 05:45 AM
Hey Tennessee!
My friend is getting the Yoshi pipe (no header though) in the next week or so. He can post the results when he gets it.
Also, Cary has begun dual sporting his bike.
Bryan...
P.S. I'll have a forum going for DRZ's too by the weekend with a pictures area and other stuff just like the WR400 forum. Thanks everyone for the 'prodding' to do this site.
  • i_carumba
Posted 22 March 2000 - 05:57 AM
Hi guys. Took a bit of looking around ThumperTalk to find the DRZ forum. I think it should be more clearly displayed. Glad to see it :)
  • Bryan
Posted 22 March 2000 - 06:45 AM
OK! You guys are getting antzy!
I am in the process of doing a full blown forum for the DRZ. If you don't tell anyone yet, I'll show it to you?
http://thumpertalk.com/suzukidrz400/
And, it's both of your fault that I HAD to do this! (just kidding)
I should roll it out by the weekend. It has a few bugs in it now.
SEND ME SOME PICTURES TO POST! ! !
Bryan...
  • i_carumba
Posted 22 March 2000 - 05:18 PM
Looking good Bryan! I will be taking an MX school on Sunday so I should have a few pitures to post after that. I will also soon be finished the dualsport conversion of my 'E' model. Will be sure to send you some pics of that too if you want. Hey Tenessee T......sssshhhhhhhhhhhhh!! :)
  • i_carumba
Posted 22 March 2000 - 05:20 PM
Oops. Sorry Tennessee T. Spelled your name wrong. Hey Bryan, is there an edit button??
  • i_carumba
Posted 22 March 2000 - 05:24 PM
One more thing Bryan. I know that you really want to buy a DRZ400E now that you have ridden one. The happy button sure is sweet. Let me know when you buy one. I promise not to tell all your WR riding buddies over at the WR Forum. Don't tell TennesseeT though. He is a blabbermouth! :) :D KIDDING!
  • Bryan
Posted 22 March 2000 - 06:17 PM
Yes, there is an edit button right above each individual post/reply. It is an icon with a pencil on it.
I like the DRZ alot but it needs some suspension work for the kind of riding I do. Plus, It's a little small for me.
But, the engine is AWESOME and the electric start, well, what can I say.
Bryan...
  • i_carumba
Posted 22 March 2000 - 06:56 PM
The DRZ fits me perfectly. I'm only 5'9"/150lbs though and ride mostly woods and mountain trails. I have read that the seating position is a bit cramped, but it is far roomier than my RMX. Was the DRZ you rode stock, or was the airbox lid removed and the carb rejetted?
  • Tennessee_Thumper
Posted 22 March 2000 - 11:19 PM
Antzy is right do you no how many years ive waited for suzuki to get with the program?Yes I apologize for jumping the gun,im usually really laid back,but I have to say im very happy for this forum and might of got a little carried away to quick.Thanks for giving it another try Bryan.
  • DR.billZ
Posted 23 March 2000 - 05:53 AM
I'm going to start adding fork oil thru the air bleeder at 5-10cc. at a time to increase bottoming resistance and add a link to the chain to increase the wheel base.
I'll probably leave the exhaust insert in. I'm really tempted to punch out the center of the insert, however.
I've taken off a LOT of unecessary clamps and crap and replaced them with zip ties. i usually ride with the head light and tail light off, unless i expect to do a LONG ride in unfamiliar trails.
Has anyone removed the radiator over flow? Results?
Keep an eye on your radiator louvers. I lost one yesterday, but wound up finding it. they are on a little loose. ZIP TIES?
  • borsy
Posted 31 March 2000 - 09:20 AM
Quote
instead of taking exhaust end cap
completely off, I altered it by pulling it off and cutting the spark arrestor solid end
cap off, then added a sleeve 1 1/2" dia. and tapped it so i can add the solid plug back on the end if I ride in the woods. I then went to the other end and opened up the size
of the exhaust tip it's about 7/8" dia.
I took a 1 3/8" dia. hole saw and open it right up. man does it breath now on top end.
sounds great not to loud. it rips.took off
airbox lid and re-jetted to 165 main.
check out www.mcnews.com.au go to tests section under drz400 good dyno's
  • Mark
Posted 31 March 2000 - 10:18 PM
borsy, how did this effect the performance on the bottom?
[This message has been edited by Mark (edited 03-31-2000).]
  • borsy
Posted 31 March 2000 - 06:27 PM
Mark, still had same power down low, which ain't much to talk about. but with it breathing so well it very responsive, a little twist goes a long way !!!
i've read going to a 48 pilot jet helps
low end, other than going to a new pipe !!
  • borsy
  • borsy
  • borsy
Posted 31 March 2000 - 06:28 PM
  • Tennessee_Thumper
Posted 31 March 2000 - 08:24 PM
Ive heard 48 pilot and 165 main and raise needle one notch.Also can put a 13 teeth front sproket.I think stock is 14 teeth.
[This message has been edited by Tennessee Thumper (edited 04-01-2000).]
  • Bigman
Posted 31 August 2000 - 08:32 AM
Hello All
It has been awhile since this was posted and there are alot more people on this forum which means more input, so lets see what everyone is running.Heres what I have done.
Kickstart model
Made a bracket out of stainless and moved the hot start button up on the inner bark buster mount
Removed snorkle on airbox
165 main jet
Tried moving the needle up on notch ,it seemed to pull a little harder but throttle response was not as crisp so I went back to stock position and like it better
Stock pilot jet
Mixture screw 2.5 turns out
I ran one of the 2 carb vent hoses from each side of the carb up and under the tank so if you are in deep water and your vent hoses are covered the carb is still vented
List of add ons
Yosh slipon pipe
Moose bark busters and plastic fairings for pro tapers
Doug Henry bend pro taper bar with 1 inch cut off each end
Scotts top clamp and steering damper
Cycra vented front number plate
Suspension revalved by MX-TECH for off road and woods conditions
Fork springs .48kg
Shock spring 5.6
Oil level 115mm currently(I have run it as high as 100mm with no problems)
WER skid plate
Bigman
[This message has been edited by Bigman (edited 08-31-2000).]
  • *william*
Posted 31 August 2000 - 01:47 PM
I'll bite.
Chucked the snorkel.
Big Gun exaust/header with S/A insert.
165 Main, stock pilot, mix screw 2.5 out.
VP C-12 fuel only.
WER skid plate.
DSP carbon fiber fork guards.
____________________________
Wish list...
Scott's damper & clamp w/ protapers.
Barkbusters
And I'm sure I'll think of more...
William
00 DRZ400E
