carb problems
7 replies to this topic
  • bigdaub
Posted August 26, 2007 - 03:42 PM
Just put a new fmf powercore 4 on my 07 yz450 + now the bike runs a little rough, and backfires like crazy on decel - what do i have to do to fix this? and does anyone know what the stock setting is for the air screw?
thanks!
  • WB450
Posted August 26, 2007 - 04:12 PM
http://www.thumperta...599#post3710599
http://www.thumperta...613#post3350613
http://www.thumperta...ad.php?t=327405
  • Ga426owner
Posted August 26, 2007 - 04:14 PM
thanks!
it needs to be rejetted for the pipe and fuel screw adj correctly.....
stock FS adj is pre set from factory.....in order to get your preset you must count the # of turns to full in and record this......usually ranges 1.5-2.2 turns out, before any adj is made:thumbsup:
  • Jekel
Posted August 26, 2007 - 07:46 PM
Also re-check your instal for any leaks. FMF should provide you with recommended jetting changes.
  • bigdaub
Posted August 27, 2007 - 05:09 PM
well i pulled apart the carb today, got my 48 pilot jet in, and then noticed that my pilot screw was GONE nowhere to be found! has anyone else had theirs fall out? Im very surprised the bike ran at all without it.
  • WB450
Posted August 27, 2007 - 06:16 PM
Yes, it sure runs like s$%#, follow the #3 I think with the new one and you should be good.
  • maddogyz250f
Posted September 25, 2007 - 12:34 PM
I have had an aftermarket screw fall out on a CRF450R but never the stock one.
Posted September 25, 2007 - 02:42 PM
People back out the screw too far to compensate for an undersized pilot (or to devote too much energy to eliminating decel popping) and end up with too little spring tension to hold the screw in.
  • 0 replies
  • Hot  79 replies
  • 5 replies
Motocross
  • Hot  491 replies
  • Hot  33 replies
