ok, new around here; and don't have a shop manual (yet)...
9 replies to this topic
  • jjnord
Posted August 25, 2007 - 06:13 PM
I'm putting in LED bulbs and have a new flasher relay too...problems...where is the flasher relay??:bonk:
thanks!
  • jjnord
Posted August 25, 2007 - 11:02 PM
come on guys:banghead:
over 20 views on this now and NO ONE out there has a service manual and willing to take a couple of minutes to look this up...please??:cry:
  • XR 650
Posted August 26, 2007 - 01:47 AM
up front of the steering column.
  • gaiiin
Posted August 26, 2007 - 02:04 AM
hey there:p , you can download the manual herehttp://194.19.84.6/xr/:thumbsup:
  • IMNXNYR
Posted August 26, 2007 - 02:05 AM
If you're referring to a xr650l, the turn signal relay is mounted on the bottom right side of the headlight stay. You should be able to get access to it by removing the headlight/number plate assembly.
  • martinfan30
Posted August 26, 2007 - 11:41 AM
thanks!
i read a thread here that said with the led turn signals you need a special flasher and have to remove the bulbs in the "dash" turn indicators. i will try to find that thread.
  • martinfan30
Posted August 26, 2007 - 11:45 AM
see rockjockeys post on the second page.
http://www.thumperta...ed turn signals
  • jjnord
Posted August 30, 2007 - 04:23 PM
ok, well I tried the Kragen electronic variable flasher=no workie, or I ordered the unit from Procycle.com. Now light flash, but like hazards; both sides at the same time. SOooo, I guessing now I need to either remove the turn signal light bulb or cut it's wire. Does anyone happen to know a "easy" way to get to the bulb? It looks like it will be a bit of a PITA.:excuseme:
  • focallength
Posted September 08, 2007 - 11:06 AM
Just a little 411 it helps to list the year and model and engine size. As the wiring for a L model and a R model is vastly different as is a 500-600-650. Also, a manual is one of the first things you should buy, they are only $30. Good luck :thumbsup:
  • pigryder
Posted September 08, 2007 - 04:46 PM
Ok heres what I did, I put in an electronic flasher, next installed resistors 10ohm I think and instead of removing the dash indicator I gounded one side of the socket and placed a diode so it wouldnt back feed and works awesome, kinda of hard to explain but I got led turnsignals front and rear and the indicator works :thumbsup:
