i hate the stock pipe
16 replies to this topic
  • T-Doshi9
Posted August 25, 2007 - 07:51 AM
i hate the the stock pipe. what pipes are you guys using on your 650ls. any good place to fine used pipes? im looking to get rid of this pipe and get the new pipe.
  • CTXr650L
Posted August 25, 2007 - 07:56 AM
i'm running an FMF Q2, not too loud and noticeable increase in power. :thumbsup:
  • Huffa 2
Posted August 25, 2007 - 01:03 PM
I run stock header but jet coated with a white brothers E series muffler.
I like that style muffler because you can tune it with the amount of disc you put on/take off and because it isn't near as long as most others + it's good looking too.
They don't make it any more though, I got mine off of ebay.
  • goblin127
Posted August 25, 2007 - 01:05 PM
XRs only full system in stainless.
  • AtomicGeo
Posted August 25, 2007 - 04:10 PM
I just put on the White Brother's new model XCR slip-on my 03 XR650L...sounds great and provides noticeable boost. :ride: Price off ebay store for new one was about $250 delivered.
  • martinfan30
Posted August 26, 2007 - 11:50 AM
i run the e2 series slip on with stock head pipe.
huffa, that header looks really nice!
my dad also has the e-series and i like its tuneability and sound better than my e2.
  • Whiteman
Posted August 26, 2007 - 12:22 PM
Plus 1
  • Huffa 2
Posted August 26, 2007 - 12:28 PM
Thanks buddy! :thumbsup:
So how does the E sound towards the E 2 if both had same # of disc on ?
Your E 2 IS tuneable too, correct ?
  • martinfan30
Posted August 26, 2007 - 12:44 PM
the e2 doesnt use disc's. it only has 2 replaceable tips/outlets. 1 is a big open hole(for closed course), the other a smaller hole with a spark arrestor screen.
  • Huffa 2
Posted August 26, 2007 - 04:30 PM
OHHHHH, I didn't know that, thought it had disc inside it, must be thinking of another muffler :excuseme:
Seems like a step backwards, I most definitly like the FINE tuning capability of the old one better.
:excuseme: Now it bugs me which muffler had inside disc, I'm almost postive I saw that somewhere :excuseme:
  • jonr3
Posted August 27, 2007 - 06:50 AM
Pro Circuit T-4. Lots more power but pretty loud.
  • axarob44
Posted August 27, 2007 - 01:25 PM
Huffa, I think the Supertrapp IDS pipe has the disks your thinking of. InternalDiskSystem.
  • Huffa 2
Posted August 27, 2007 - 02:06 PM
Thats the one ! Thank You ! :thumbsup:
  • squatpuke
Posted August 27, 2007 - 03:45 PM
Goblin...I'm considering the Full XRO full stainless also....however, I've heard the stock header has a much better fit than ANY aftermarket headers...
What's your take with the aftermarket XRO header? Good fit?
Huffa has a nice stock header setup...might be a better way to go...
  • motomonte
Posted August 27, 2007 - 04:16 PM
I just installed the Supertrapp ISD2 quiet series.The intallation was really straightforward (about 30 mins.)The sound is a little more than the stock pipe but not that much.And it does increases power.Has lots of low end grunt,haven't tried at top speed yet but then it's tunneable.
  • goblin127
Posted August 27, 2007 - 04:46 PM
I think the header fit was very tight,its only been mounted once and sofar I can't detect any leaks. The tail pipe section was a little frustrating at first,but it went together and have not had any problems. The header it larger diamiter than stock,but you probably know that.
  • MartinDKtm
Posted August 28, 2007 - 03:16 AM
On my 2000 650L I run a Fmf header with an older xl600 pipe and I did removed the small plate to remove carbon (thats what the manual says...) under it. I have a supertapp but was never able to tune the bike with the supertrapp on it. Sound is an issue for me so the stocker is nice. The Xl 600 pipe does flow much better than the stock L unit. The output pipe is much bigger. I think it cause the Xl had a better flowing head because of the dual carb setup.
  • 3 replies
  • 9 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Honda XR650L 2016
  • 0 reviews
