New Muffler Getting Too Hot
11 replies to this topic
  • 02YZ426
Posted August 22, 2007 - 06:20 PM
No my header is not glowing LoL. . I just put an FMF Q4 on my YZ and it gets so hot its starting to melt my number plate! First thought that comes to mind is that jetting may be out, but the bike runs great as is. The instructions also say no jetting changes are required. So I have 2 questions. For guys who run this pipe, do you have this same issue? And would adding some kind of heat shielding material to the back side of the plate be the proper fix or is there another answer? Just to note there is plenty of space between the number plate and pipe.. also the graphics on the pipe have almost melted off. Thanks in advance for your imput :thumbsup:
  • MRD RACING
Posted August 22, 2007 - 06:28 PM
it requires baffeling to quiet these bikes down , and baffeling causes the muffler to run allot hotter than a straight through design , its not a problem when trail riding , but it sounds like you are running your bike hard and its not uncomon to burn off the stickers and melt number plates when you run a quiet pipe hard , adding some heat shielding to the plate is about all you can do :thumbsup:
  • 02YZ426
Posted August 22, 2007 - 06:58 PM
Thanks.. I didn't think of it that way. Anyone know of heat shielding that is sold specifically for something like this?
  • ringding
Posted August 22, 2007 - 07:01 PM
yeah, there is a type of stick on sheilding, fox used to make it
Posted August 23, 2007 - 05:54 AM
Your number plate should have something on the back of it on that side as it is, but if not, you need something like this:
http://shop.thumpert...fault.asp?p=478
  • jrny426
Posted August 23, 2007 - 06:16 AM
when I had this problem there was no packing in the muffler.
  • KAS
Posted August 25, 2007 - 02:02 PM
How do you like the Q4 muffler, besides this problem?
Is it quiet? I'm really not worried about losing much power on a 450, I just need to quiet this thing down for the woods.
  • GONE1445
Posted August 25, 2007 - 07:28 PM
your bike should have come stock with heat sheilding on the back of the number plate (mine is falling off big time so that might be why yours isn't there anymore)
  • cowboyona426
Posted August 25, 2007 - 07:32 PM
The 06's, at least mine, don't come from the factory with any heat shield behind the side plate.
  • MACHINEST
Posted August 25, 2007 - 07:34 PM
You can also use a spray ashesive and aluminum foil in layers just be sure to prep the surface and shiny side out.
Posted August 25, 2007 - 09:15 PM
That's how mine is, too. The add-on/replacement stuff from Maier or elsewhere will work, though.
  • 02YZ426
Posted August 26, 2007 - 05:45 AM
I like it.. looks trick, no jetting changes needed and it seems to kill how far the sound carries. Its not very quiet when your standing beside the bike revving it though. From what my friends have been telling me its just quieter from a distance.
  • 10 replies
  • Hot  36 replies
Motocross
  • Hot  491 replies
  • 9 replies
  • On January 15, 2017
