What will these 2 mods on my new XL650 do?
5 replies to this topic
  • xrberg
Posted August 22, 2007 - 10:48 AM
2003 XR650L 500 miles
Thinking of leaving the carb mods alone for now since I only have 500 miles on my bike. I'm a pretty goosd DIY mechanic but I just dont have the nuts to drill that sucker out. so..........
Just wondering if I just remove the air pump and charcoal canister and maybe add a supertrap if I'd be good to go and get some decent performance. It seems like a uncorked 250 right now. What can I expect with just those mods.
oh and btw I have a supertrapp off one of my XR250rs and it looks like it will fit.. anyone chime in and tell me it will be too restrictive?
opinions appreciated
  • martinfan30
Posted August 22, 2007 - 10:58 AM
drilling the slide is very straight forward and will cause no prob. unless you drill out the needle hole!LOL!
removing the smog/charcoal cannister does very little other than save a bit of weight.
if you put on that s.trapp, it wont run right w/o doing the carb mods--will be even more stupidly lean.
so do the carb stuff with the pipe. the smog removal can be done by itself.
  • COAL RUN
Posted August 22, 2007 - 11:50 AM
If you dont want to drill the slide you would at least need the jet kit
  • martinfan30
Posted August 22, 2007 - 11:52 AM
i did both. had great t. response. but now the fcr 41 rips!
  • Denn10
you dont need the jet kit you can just get jets. I would do the carb mods and rejet cuase stock jetting is known to be lean, so unless you riding from about 6k feet and up your prolly off a bit. I was a bit scared too to drill the slide but i just did it in a few steps like 2 smaller bits till i got the 5/32 last one its easy once its over and youll like the 250 power increase double.
  • Frank ZX
Posted August 22, 2007 - 12:31 PM
Drilling the slide does wonders,along with larger jets,and shimming the needle.My 02 would only pull the front tire in first gear before.Now I cruise along in 2nd,pin the throttle and it's a unicycle.lol.It's the biggest performance gain for the buck.
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  35 replies
  • Hot  60 replies
Honda XR650L 2017
  • 0 reviews
