yz 400 engine trouble - aluminum in oil
2 replies to this topic
  • chillie
Posted August 22, 2007 - 07:46 AM
I have a 99 yz 400 - after a long hot trail ride a couple weeks ago I was quite disturbed to find the oil was full of aluminium powder and flakes. After that I no longer needed to pull the decompression lever to kick the bike over. The engine still runs, but sounds awfull. I don't want to run it anymore, I guess it's time to pull the engine apart and find out what went wrong. Has anyone had this happen, any ideas what parts I might need to replace/repair. I have never pulled it apart, but I have the shop manual. I guess I'm out for the season.
thanks in advance
Chillie
  • 00 Kracker 00
Posted August 22, 2007 - 04:58 PM
Possibly bearing material from a bad bearing.
Or it could be clutch material. But if the engine isnt running right anymore, then its probably a bearing failure.
  • stnkbg1
Posted August 23, 2007 - 12:16 AM
Are you sure it's aluminum? If it were a bearing failure the bits and pieces would be mainly steel. Aluminum is far too soft to be a bearing material. My guess (total guess) would be a scored cylinder/piston, and the aluminum is bits of the piston skirt, if of course the piston is aluminum, is it? That could explain compression loss (past the rings) and running badly.
Dallas
Motocross
  • Hot  491 replies
  • 5 replies
  • 0 replies
  • Hot  79 replies
