why does my 650L do this?
12 replies to this topic
  • jeanluconze
Posted August 21, 2007 - 08:05 AM
after completely warmed up, the shifting gets clunky, throttle looses its snap, bike just feels less "tuned in". For the first 15 minutes or so, it's great. Shifts smooth, throttle is snappy, bike sounds great. What could this be?
  • Denn10
Posted August 21, 2007 - 09:10 AM
is this a new problem that just started or ongoing thing?
  • jetfuel
Posted August 21, 2007 - 09:39 AM
sounds like more than one problem.. have you cleaned the air filter recently? a dirty filter will throw things off once warmed up. have you changed the oil recently or not? as Denn10 said a little more info is needed...
  • jeanluconze
Posted August 21, 2007 - 11:03 AM
Some more information:
This has happened since day one. Changed the oil 400 miles ago, 10-40w HP4. Uni filter is clean and properly oiled. 1k miles on it. Never checked the downtube screen.
I'm wondering if the fuel mixture screw is jacked somehow.... when turned in all the way down, should it seat against the carb or is there still a gap? Mine doesn't seat all the way down. I have it 2.5 turns out from where it stops and it's really hard to turn (that could be because I ground the tab off, though).
At start up, i use the choke half way for maybe 5 seconds. After warm it starts up fine, sometimes needs a little throttle but not much. Temp dipstick shows 230 to 250 at fully warmed, riding around streets. The oil "feels" too thin, like it's not sticking to the gears. It doesn't burn oil. No smoke on accel/decel/idle, very little popping.
  • Denn10
Posted August 21, 2007 - 11:12 AM
problem from the start HMMM check this out about your fuel screw and see what that does for ya, it may not be the perfect jetting for your area as the dave's mods recomendations are not perfect for everyone, im using 58/162
http://www.thumperta...ad.php?t=327405
Your clunking on shift is prolly from the oil, i know mine does a tad bit but from my street bike i switched from HP4 to Mobil1 4T full synthetic and it helped alot, clunking on my cbr600rr is a common thing though. Havent seen alot with the Ls and complaints on that though.
  • martinfan30
Posted August 21, 2007 - 11:59 AM
i use the honda oil 20w-50 in summer. this may help.
  • Denn10
Posted August 21, 2007 - 01:53 PM
yeah i was told by XRs only use the 20/50 all year for us in CA and LV fools too. GOOD EYE martin
  • jeanluconze
Posted August 21, 2007 - 02:35 PM
I already bought some GN-4 20/50 for the next change. I'll probably go with synthetic after that. As for the fuel screw, is it normal that I can turn it 1 full turn either way from 2.5 turns out and not notice a difference in idle speed?
  • Frank ZX
Posted August 21, 2007 - 02:36 PM
My XRL shifted clunky also.I switched to 15w40 Rotella oil,now it shifts smooth.
  • martinfan30
Posted August 21, 2007 - 02:45 PM
my fcr does this too. this usually means the pilot is too big. or should i say that if you can turn it all the way in with no change, that means pilot is to big.
  • goblin127
Posted August 21, 2007 - 04:47 PM
Changing to synthetic oil helped my tranny shift better also. Noticed it right away.
  • axarob44
Posted August 21, 2007 - 05:18 PM
Same here with 20w-50 Mobil 1 synthetic smoothed out the shifting.
  • beezerjoe
Posted August 21, 2007 - 05:29 PM
Running problem might be valves getting tight when it warms up.Check your clearances.
  • 17 replies
Washington
  • Hot  32 replies
  • Hot  29 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  186 replies
