FMF jetting kit
1 reply to this topic
  • Lennie
Posted August 21, 2007 - 06:51 AM
Hello,
I have a JD jetting kit on my 2004 WR450 currently and the bike runs nicely but i have just got a full FMF factory 4 full exhaust system (inc header) which included the FMF jetting kit. My friend has the exact same bike with the same exhaust and JD jetting kit and his bike runs well so i know its a good combo.
Does anybody know much about FMF jetting kits? Are they any good?
Which jetting kit would you use, stick with the JD or swap it for the FMF?
Cheers
Lennie.
  • Michigan DS
Posted August 21, 2007 - 07:36 AM
I believe the new exhaust will make your bike run a little leaner. If you had the bike jetted perfectly prior to the installation, you might want to go one richer on the jetting. If you were already a little rich you might be fine.
I would post this question on the Jetting board and email JD. You should get a knowledgable response from both.
Good Luck,
Doug
