2007 wr flat spot
4 replies to this topic
  • DR EVIL
Posted August 20, 2007 - 08:47 PM
I have a 2007 wr 450 with a low range flat spot. I have done al the free mods and the bike runs great as long as you keep the rpm's up a little. It still has the stock jetting.
  • KennyMc
Posted August 20, 2007 - 11:24 PM
If you have done all of the free mods including the AIS removal, I believe you are running lean. I installed the JDJetting kit with the 168 main and 48 pilot and red neddle on the 4th position. Also installed the ZYpty fuel screw turned out 2 times. My stock bike came with a 162 main jet and a 45 pilot jet. Try this and see if it gets you closer to oz.:applause:
  • JSanfilippo
Posted August 21, 2007 - 12:56 AM
JD jetting and the o-ring mod will cure whatever hiccups you may have in your throttle response.
  • DR EVIL
Posted August 21, 2007 - 07:44 AM
what is the o ring mod
  • JSanfilippo
Posted August 21, 2007 - 10:22 AM
In the JD kit, they supply two o-rings (a small one and a thick one) that you can slip over your accelerator pump linkage to make the off idle response pretty much instantanious. You can get 10mm o rings in various thicknesses at a motorcycle shop or you can do what others have done and saftey wire the linkage.
