Stripped tank inserts
11 replies to this topic
  • bumblebee
Posted August 20, 2007 - 08:01 PM
well the inserts that the radiator shroud bolts go into on the tank....there is one that just spins.....i cant get the bolt to back out cuz the insert does not hold and i need to switch plastics!!! so is there anything i can do???? thanks
  • nicholasd450
Posted August 20, 2007 - 08:20 PM
i done the exact same thing on my 250f!...why cant they put square inserts in the tank:S......i got lucky tho...mine was the bolt that i puts my knee over..so all i done was rip the stock shroud off...and make the whole there bigger on my new shrouds...it doesnt flop off but i can pull it off right there
Posted August 20, 2007 - 10:07 PM
http://www.thumperta...747#post4665747
  • djtroy
Posted August 22, 2007 - 11:47 AM
I took a socket (8mm) attached it to a high speed drill. I turn the nut fast enough that it heats up the plastic and eventually it gets hot and you can pull it right out of the tank with ease. Then just clean up the hole and put it back in the tank and epoxy it and thats it. I have done this a couple of times now and its easy.
  • WB450
Posted August 22, 2007 - 12:18 PM
Funny how the day after I run to this there is a bunch of info on it. I'm stuck with busted off bolts in the inserts. I'm going to drill them out and re tap it with a 8mm, there should be enough meat there to work. I used anti seize on the new tank.
  • WB450
Posted August 22, 2007 - 12:20 PM
The dumb ass behind the counter at the local Yamaha dealer told me that the insert was molded and reinforced in the tank, and it wouldn't come out.:banghead:
Posted August 22, 2007 - 03:37 PM
Right. :rolleyes: That's why they spun loose in the first place, ain't it?
  • WB450
Posted August 22, 2007 - 07:12 PM
The inserts didn't spin loose in the tank, the bolt spun in the insert coming out, both sides of the tank.
  • djtroy
Posted August 22, 2007 - 08:07 PM
Ya and you explained it way better than I did too. :applause:
Posted August 23, 2007 - 06:13 AM
Did you get it fixed?
Posted August 23, 2007 - 06:14 AM
I think most people understood your explanation of it. :thumbsup:
  • WB450
Posted August 23, 2007 - 06:55 AM
Not yet I have a new IMS, so it's not a real big deal. By the way, I did a search on petcocks and the info you provided helped me out with a 05 petcock.:thumbsup: Thanks.
Motocross
  • Hot  491 replies
  • 9 replies
  • Hot  33 replies
