Wr400 2000 - rear shock maintenance
6 replies to this topic
  • holdon
Posted August 20, 2007 - 04:24 PM
just a quick one - ive gone to grease up my rear shock and ive noticed there are no grease nipples....
how do i service the rear shock?
  • dr x
Posted August 20, 2007 - 04:35 PM
All you can really do is grease the top and bottom bushes, other than that its take it apart and rebuild it but i wouldnt recommend doing that unless you know exactly what your doing....
  • holdon
Posted August 20, 2007 - 04:45 PM
oh ok.....so these are a "maintenance" free item.
it was just squeaky and clicky the other day so i wanted to pump some grease into it.
thanks for the response
  • dr x
Posted August 20, 2007 - 04:53 PM
Might be worth looking at the linkage to see if that needs some grease.
  • Solo
Posted August 20, 2007 - 10:39 PM
Take the whole swing arm off and grease everything. The world will be a better place if you do.
  • Jekel
Posted August 26, 2007 - 03:36 PM
Grease the bushing for the shock mounts real good as these will give a annoying squeek at times. Also grease all the swingarm and suspension bearings as noted earlier. This will really improve the ride....
  • Martys
Posted August 26, 2007 - 08:08 PM
If you want to service your shock and you're not quite comfortable with it you can check out the Shock Maintenance DVD from Motopower. I personally think it is easier to do the shock than the forks.
http://www.motopowervideo.com
