Primary Reduction Ratio
8 replies to this topic
  • DPWR400
Posted 19 August 2007 - 08:01 PM
First of all what gears are they using as primary reduction ratio? Second do all DRZ's have the same ratio of 2.960 (74/25). I have an 05 SM but only have a S shop manual. Lastly do all DRZ's use a 15 tooth counter sprocket stock? Thanks All!
  • g935cab
Posted 19 August 2007 - 08:41 PM
sm-15-41
s- 15-44
e- 14-47
  • William1
Posted 20 August 2007 - 03:02 AM
Primary for all bikes is 2.960 (74/25)
g935cab gave final ratios
  • DPWR400
Posted 20 August 2007 - 05:32 AM
Cool thanks for the info everyone, but I'm still curious how the primary reduction ratio is computed? Anyone??
  • jlbenne
Posted 20 August 2007 - 06:18 AM
By teeth on the gears and simple division
74 divided by 25 is 2.96
  • MutualBill
Posted 20 August 2007 - 06:39 AM
to calculate final drive ratio of a given gear combination...divide the drive gear by the driven gear (tooth count).
This will give you your gear ratio. For example  15/44 ratio equals .340909090...or simplified...gives you a what is normally known a 3.40 drive ratio.
You multiply that number number by the gear ratio of the gear you have selected in the Transmission to achieve your total final drive ratio.  By the way...the DRZ does not have a 1:1 ratio on any of its gears.  4th is slightly under driven and 5th gear is slightly over driven.
If you search...sombody did post the ratio of all 5 gears for the drz in the past.
  • DPWR400
Posted 20 August 2007 - 05:51 PM
okay so the primary drive gear has 25 teeth so that is where the 25 comes from but where does the number 74 come from?
  • DPWR400
Posted 20 August 2007 - 06:08 PM
I think I figured it out, the primary driven gear has to be the clutch basket, is that right??
  • Noble
Posted 20 August 2007 - 10:06 PM
Right. 74 teeth on the clutch basket
