1st Valve Check - Oil Change question(the process, not the kind of oil =).
3 replies to this topic
  • jhawker21
Posted August 18, 2007 - 06:08 PM
Hey guys -
I have an 02 YZ426.
I attempted my 1st valve check today and it couldn't have gone better. I was able to get to the valve's, all were in spec and looked good! I was very excited that they were in good shape! I did notice some dirt/gunk in my spark plug hole that worried me a bit. Any ideas on how to clean it out without pulling the plug and coating the top of the piston with dirt?
I also changed the oil in my bike for the 1st time.(I bought it used in May and have run about 8-10 hours since) so it was time for a change. I was able to do everthing but I could NOT get the screen out at the bottom of the frame. The book says it's torqued to 65 ft.lbs. Anyone have a trick or the best way to get this out? I pulled as hard as I could and no budge.
Thanks for the help!
Eric
  • dirtrider04
Posted August 18, 2007 - 06:53 PM
dont bother with the screen not much comes out
kinda point less as far as the sparky i dont know how stuff got in
Posted August 18, 2007 - 08:26 PM
Unless there's been some major failure, or an overhaul done, there's not much reason to pull the screen. It's analogous to the pickup screen in the crankcase of a wet sump system, and they never get cleaned unless the engine's apart, mostly.
It requires a 6-point, 26mm deep socket, and someone to hold the bike.
  • jhawker21
Posted August 19, 2007 - 02:57 PM
Thanks Gray!
I was thinking it may be the least necessary part of changing the oil but wanted to make sure!
Thanks for all the help! I love TT, it's great for learning how to maintain my bike.
Thanks,
Eric
  • 0 replies
  • Hot  36 replies
  • 5 replies
