scary at higher speeds..
10 replies to this topic
  • bigwake
Posted August 18, 2007 - 03:42 AM
could my handle bars shake at higher speeds because of the way the bars are positioned?..i just noticed that my bars are forward and my buddy's bars are back considerably more..and he does not have this problem..im on an 03 yz450..and hes on an 03 kx250..just wondered..
  • King_Air
Posted August 18, 2007 - 06:07 AM
How high are your forks in the triple clamp? I think this would have more to do with headshake than bar positon. How fast are you going when you get the headshake?
  • rexbond007
Posted August 18, 2007 - 02:52 PM
first i would check front wheel bearings,
i don't think handle bar position has anything to do with high speed shake.
  • KJ790
Posted August 18, 2007 - 03:24 PM
Is your sag set? Is your suspension sprung for you? These are the two biggest causes of headshake.
Posted August 18, 2007 - 04:01 PM
If you had read some of his other posts, you'd know the answer. He has stock suspension, and he weighs 255. We've tried to tell him that it's all uphill until he gets the springs changed, but so far, he keeps hoping to make it work without that.
  • KJ790
Posted August 18, 2007 - 05:25 PM
Yeah, I have seen some of his other posts. I was just feeling hopeful that he had tried setting it up, or at least feeling like reiterating it would make him decide to set up his suspension correctly.
Posted August 18, 2007 - 07:27 PM
Gotcha. :thumbsup:
  • tom nolan
Posted August 21, 2007 - 07:41 AM
I have a 98 400. I had the same problem until I installed a Scott's Stabilizer. progblem gone. I ride most of the time in the desert with 5th gear pinned. My gearing is 15/44
  • mxrayser
Posted August 21, 2007 - 03:12 PM
Hot Doggy, what do you top out out at about 212mph:eek: Hows the hillclimb ability?
Posted August 21, 2007 - 05:03 PM
theoretical top end (calculated, ignoring wheel slippage) would be 100 MPH @ 10,000 RPM in 5th, IF it could pull that many revs in that high a gear.
  • bigwake
Posted August 22, 2007 - 05:27 PM
hahaha..sounds fast enough for me
