How much metal in oil filter is normal?
6 replies to this topic
  • Kasjok
Posted August 17, 2007 - 10:57 PM
It seems like I have had more and more metal in my oil filter lately. I try to get some pictures when I am going to change the oil again. Bike is from year 2004 and I have changed my oil and filter after every 5 hours.
  • BergArabia
Posted August 18, 2007 - 03:58 AM
Not sure but I would be thinking might be time to check the clutch and basket..
  • NEKOOHC
Posted August 18, 2007 - 04:08 AM
zero metal in the oil filter is normal , it is normal to have a slight metallic paste on your oil drain plug magnet .
metal in the filter could come from a bearing or rockers / cam .
it is hard to say until you inspect internally .
Posted August 18, 2007 - 08:52 AM
It's not at all unusual to find metal debris in the filter, but it should be relatively fine. Slivers of aluminum from the clutch basket/boss are the most common, followed by random chips and slivers from the transmission.
Squarish, flake shaped chips indicate a bearing failure. And of course, the overall quantity found is important, too.
  • mike_dean
Posted August 20, 2007 - 04:00 PM
I have 500+ hrs on my YZ426 and have metal in my filter at every oil change, oil changed every 3-5 hrs with mobil 1, bike runs perfect no mechanical failures, has had 1 piston ( didn't need it), has a hinson clutch basket since new, I wish I knew where it comes from, but I guess it doesn't matter. Mike
  • NEKOOHC
Posted August 21, 2007 - 06:37 AM
500 plus hours .... gotta be happy with that !
  • mike_dean
Posted August 21, 2007 - 11:07 AM
chooken, very happy with it, most dependable mx bike I've ever owned. I don't overrev and it comes stock with stainless valves, that helps. Mike
  • 0 replies
  • Hot  38 replies
  • 10 replies
