HELP! Need Pics of WR Coolant Overflow Tank -
22 replies to this topic
  • neokinetiks
Posted August 16, 2007 - 01:52 PM
I have an 02 YZ426 and need to install an overflow tank.
Can someone please take me some detailed pics of how your WR has the overflow tank mounted, and were they run the lines.
Thanks.
  • MountainMax
Posted August 16, 2007 - 03:13 PM
I can take some pics of my 06 if you think that would help, let me know.....
  • dustinw
Posted August 16, 2007 - 03:46 PM
this one probably won't help much....
  • byggd
Posted August 16, 2007 - 03:50 PM
I'll see if I can pull the side cover off my 02 and get some shots..........stay tuned.
  • byggd
Posted August 16, 2007 - 04:11 PM
http://s18.photobuck...nt=P1000976.jpg
http://s18.photobuck...nt=P1000975.jpg
http://s18.photobuck...nt=P1000974.jpg
The hose in the bottom of the tank goes to the radiator and the top hose goes down where the hoses from the carb dump out..
  • Alternative
Posted August 16, 2007 - 05:53 PM
You'll need a WR subframe or modify your one to mount the tank. The YZ subframe doesn't have the tabs to bolt the tank to.
  • dmoney1074
Posted August 16, 2007 - 06:13 PM
Not nessesary... dont make mounts, just zip-ty it to your subframe. Many people make thier own overflow tank out of turkey basters, or something. Get creative!!! :ride:
  • neokinetiks
Posted August 17, 2007 - 06:13 AM
Thanks for the Awesome pics BYGGD.
The tank should be to me in a few days, then I will let you guys know how the install go's.
  • byggd
Posted August 17, 2007 - 10:34 AM
Not a problem! :thumbsup:
  • SJMC_DON
Posted August 17, 2007 - 10:38 AM
I've seen a thread in here, and you might find it by searching, but there were pics of one made with a 8" or so length of PVC pipe capped at both ends with a supply/return line and overflow line tapped into the top and the whole thing was zip tied to the frame or rad guard on the LH side of the bike... it looked good, cheap and effective:thumbsup:
  • byggd
Posted August 17, 2007 - 02:27 PM
That sounds like a good idea and easy enough to make. But how would you read the fluid level?
  • neokinetiks
Posted August 18, 2007 - 05:29 AM
I found a YZ450 catch can for $18 shipped off eBay.
I just got it in last night and once I get it hooked up I'll take some pics and post.
  • neokinetiks
Posted August 18, 2007 - 05:34 AM
Oh Yeah! One more thing.
On the catch can I got (YZ450) it has 3 lines connected to the bottle. What are the 3 lines for?
1. Is for the vent.
2. Is for the overflow to push the coolant back into the bottle, then suck it back into the radiator.
3. What is this one for?? Its located by the top of the bottle right under the cap.
  • neokinetiks
Posted August 19, 2007 - 03:11 PM
Got the overflow tank installed.
Everything was very simple, it was off a 05 YZ450F, so very little mod's had to be made.
Now I cant wait to get out there and see how it does.
Thanks for all the help guys!!
Before.
After.
  • byggd
Posted August 21, 2007 - 11:20 AM
You run the e-series with no plate or discs? It must rattle the wax loose in your ears :eek:
  • SJMC_DON
Posted August 21, 2007 - 11:26 AM
uhhhh.... he didn't even wash it, or even knock the mud off before installing the new part. :busted:
Loud sucks!!!!!!!!!
  • neokinetiks
Posted August 22, 2007 - 05:33 AM
Its very loud no matter if it has the spark arrestor/disc on it or not.
The disc make the exhaust heat start mis-coloring the side of the rear fender decals and fender.
So I usually run them off.
  • neokinetiks
Posted August 22, 2007 - 05:36 AM
Loud sucks!!!!!!!!!
Yeah I usually have it spotless, and everyone gives me a hard time cause I'm detailing a "Dirt Bike".
But I have a 5 week old baby, and he did not want to cooperate so I could clean the bike.
I was lucky to get time to do the install.
  • byggd
Posted August 22, 2007 - 07:41 AM
I agree and disagree. When I bought my 02 it had the e-series set up like you have it and it was WAY too loud. I added the spark arrester, 4 discs and the quiet core insert and while it was still loud at WOT it helped a lot. Keep in mind every disc is = to a 1/4" opening.
  • SJMC_DON
Posted August 22, 2007 - 11:51 AM
I understand.... I was just flipping ya some sheet :busted:
