Header Wrap
42 replies to this topic
  • SRT426
Posted August 16, 2007 - 12:10 AM
Did a search and got some info on wrapping my header (keeps burning my pants), and it seems like a good idea to solve my problem. What I need to know now is to hear from some people who have been using this for awhile and get some feedback on if you had any bike problems as a result or if you recommend it. Thanks.
  • BergArabia
Posted August 16, 2007 - 02:21 AM
I am also interested to hear some feedback on this. Sorry I don't have an answer to share but I would also like to know where to get some..
  • VOODOOCHILD
Posted August 17, 2007 - 07:16 AM
I work part time at Advance Auto and we carry some from DEI. I ordered in some black that was 1 inch wide. It also comes in white and different widths.
Most auto parts stores should be able to get it. I've been running mine for about a year now and love it. No problems. I got tired of seeing bikes with the stock beatup guard and not having a guard myself. I cut the tabs off and painted my entire exhaust with header paint and baked it on with a heat gun then wrapped the guard area and secured the ends with hose clamps. Works good. They recommend some silicone spray that I haven't tried yet ,but may. I will try to post some pictures of my bike soon.
  • turbogtimk4
Posted August 17, 2007 - 02:46 PM
I have a wr426 and wrapped the stock header because my bike was over-heating the radiator. The bike runs way cooler. now i have a full big gun system and re-wrapped the header. still works awesome!
  • 450GN
Posted August 17, 2007 - 03:23 PM
bike doesnt run cooler.... heat just doesnt radiate off of your exhaust and instead exits out the muffler like it should!
i was thinking about doing this and might... still unsure and glad to hear all pos feedback so far
  • KJ790
Posted August 17, 2007 - 03:56 PM
You can buy a pipe guard too.
  • Jekel
Posted August 26, 2007 - 08:10 PM
I can't hurt to wrap the exhaust. May make the bike perform better. Was always going to try this, but never got around to it:-)
  • toombstone
Posted September 02, 2007 - 03:11 PM
wrapped mine and "lemme tell ya sumpin" it does'nt lose that snap you have when it's still cool. My 07 would get "doggy" when it got hot. and August in Florida is HOT. So as the Fabulous Thunderbirds would say
Wrap, Wrap,..... Wrap it up.
Rod.
  • kickinfetus
Posted September 02, 2007 - 09:09 PM
i wrapped my stock pipe and it worked out great. when i got an aftermarket with a steel head pipe tho i heard it wasnt a good idea to wrap it cuz of the possibility of rusting and eating through the header.....water dude......it soaks in and sits......might work if after you wash your bike you start it and dry the wrap off by letting it idle. idk
  • maxx2200
Posted September 11, 2007 - 06:48 AM
I bought mine from NAPA. It was white but turned almost black after it cured. It not only looks cool but it provides a barrier for the radiator. Make sure you wet it before installation so it's pliable and it is very easy to put on.
  • NorCal
Posted September 11, 2007 - 07:41 AM
Post some pics.
  • maxx2200
Posted September 11, 2007 - 08:16 AM
Post some pics.
I will, as soon as I can.
  • stroker yz426
Posted September 11, 2007 - 10:24 AM
i havent wrapped mine...but i didnt send my pipi in to get jet hot coated inside and out.....its like a heavy duty ceramic coating the keeps temps done....the stock pipe was done when i got the bike...and i noticed that with out the heat shield she ran a lot cooler then my buddies yz with the stock pipe and heat shield uncoated......you can ever pay a lil more and get it sterling coated to make er shine if ya care that much......i had the muzzy full exhaust system...(i found it dirt cheap from a private mech locally un-used for 150 bucks so to get er piped i installed it and had the head pipe coated after the first trip to dumont.....i melted my pant and jersey twice.....but after the coating no worries....especially if you stop to chat or take a short break....and stretch your leg out(thats when i melted mine)its cheap and worth it...it even adds a lil extra thickness to the pipe...i crashed on mine and thought id have a hugh dent...nope nuttin but small surface scratches....i guess if you needed it you could wrap it as well
hope it helps
  • Uncle_Rich
Posted September 11, 2007 - 03:09 PM
I've been doing mine for years
I did it to keep the bike cooler, works great
I got mine at Summit Racing http://www.summitracing.com/
Rich
  • Fastest1
Posted September 11, 2007 - 04:42 PM
Lets see, if it doesnt radiate heat off the header in the area of the radiator, then it allows the radiator to dissipate more heat AND it runs cooler. It also sounds much better! Did it in RRing for years.:thumbsup:
  • swatdoc
Posted September 13, 2007 - 04:38 PM
Any issues anyone knows of by wrapping a titanium headpipe?
Heat is gonna be an issue for me with my street legal supermoto 450, mostly when stopping at a light with no airflow. Any little thing to slow down the overheating is good. Doing a lot of these ittle things will hopefully make a difference
  • toombstone
Posted September 23, 2007 - 08:04 AM
Hope ya like
[IMG]http://http://www.triwheeler.com/yz/wrap01.jpg[/IMG]
rod
  • toombstone
Posted September 23, 2007 - 08:06 AM
Posted September 23, 2007 - 09:09 AM
As long as you are running a full street electrical system, you'll get far more from running a pair of small DC computer chassis fans than from wrapping the header, and it won't look like the return of the mummy.
  • swatdoc
Posted September 24, 2007 - 02:37 PM
Gray - I'm keeping the output AC, as a rectifier will suck up some available watts (I'm told).
Only have 50 watts total - headlight will use 35, and LED tail light only about 1. Leaving only minimal watts at best.
Not totally opposed to a couple small fans, but they would need to be AC and be very low wattage draw. Any suggestions on that?
Probably gonna have my friend steve make me a carbon fiber shield to go between the header and the radiator so I won't have to use the mummy tape.
