98 WR400F jetting question for James
2 replies to this topic
  • Henry
Posted January 25, 2001 - 08:47 PM
Hi James,
I have studied your jetting diagram with great interest.
Does the EK* series needle really helps to boost up the bike?
My bike is jetted in the following , showed in my signature. I'm riding at sea level, does changing to EK* needle have any different?
By the way, I have the stock main air jet though, will change it together with the EK* series needle. K or P for me?? :)
'98 WR400F, YZ timed, main:180, pilot:48, DVR needle 4th clip from top,
snorkel removed, YZ tank/seat combo, YZ front no.plate/rear fender,
DSP Ti exhaust system, Brembo front brake,steel braided hose, EZ clutch adjust perch,
Stroker billet rear brake reservoir
  • Taffy
Posted January 26, 2001 - 01:50 AM
he's on holiday.
if he said it he meant it.
i ride at sea level on a 99WR
i run a std DXM needle on clip 6. tthis is fine but could be better.
my advice is yz iming, 100 air jet, std 45 pilot, 1 1/2-2 turns out on the pilot screw, i've bent the acc. pump arm (the one with two prongs) down & out so that the pump does less work.
he says the EKP needle is better, i believe him so try it. i find JD's settings a little rich so try it on 3rd clip.
Taffy
  • James_Dean
Posted January 31, 2001 - 08:52 PM
The short answer-
EKP#3 or EKP#4 (Same as '01YZ426)
one step richer off idle to 1/8 throttle-
EKN#3 or EKN#4 (Cooler temp option)
The difference is like splitting hairs. :)
James
