Head light bulb?
5 replies to this topic
  • 767driver
Posted August 15, 2007 - 12:41 PM
Ok My headlight went Tango Uniform. I pulled the bulb, and it appears to still have the filament intact. I tracked the wires and they appear good. Any thoughts?
Anyone know where to get a replacement bulb without having to go to the local Honda shop, 80 miles away.
Thanks!
oops, I forgot its 2002 Xr650r
  • Denn10
Posted August 15, 2007 - 12:47 PM
is it a XRL? if so i replaced mine was a H4 bulb that i got at auto zone seems to be a widely used 12v bulb for cycles.
  • 767driver
Posted August 15, 2007 - 12:56 PM
I think I sent my edit right when you were responding, sorry about that. Yeah it's an R model, might be the same bulb though, but I doubt it. I think the L has to have a high beam for DOT.
  • cleonard
Posted August 15, 2007 - 02:05 PM
You might want to check the bulb with a meter to be sure that the problem is not something other than the bulb.
The best thing to do is just mail order one. I would be bad to drive to the dealer only to find out they don't have one on hand.
There is a PIAA replacement that gives a little more light. The downside is it is expensive at about $30. I think with a little grinding and wiring a H3 bulb can be made to fit. You can get one of those at any autoparts store or even Walmart.
  • exaresix
Posted August 15, 2007 - 03:36 PM
Here's a good mail order site:
http://www.hondapartsdirect.net/
  • 767driver
Posted August 15, 2007 - 03:39 PM
Yikes!
Interestingly enough the kill switch is run thru that same circuit. I had the bike idling so I could check the light, when I went to turn it off (keep it from overheating)the kill switch wouldn't work. I had to put the light bulb casing back togehter to turn off the bike. Weird.
