WR450 plastics on a WR400
3 replies to this topic
  • hozhead
Posted August 14, 2007 - 07:03 PM
I've done several searches with no luck so here goes...
Has anyone done a full plastic swap from an 03-06 WR450 to a WR400?
- I've got a 2000 WR400 Supermoto that could REALLY use a YZ style tank and seat for better seating position. I'm considering an aftermarket, high capacity YZ400 tank but would prefer to use a WR450 tank, seat, shrouds, rear fender, number plates, etc.
- I'm not opposed to swapping the subframe and airbox but I need to know if that's possible before buying the parts and I don't know anyone with a WR450 that I can pull parts from to test.
I saw that the "Team Scream" YZ426 has some 450 plastics but there weren't many details in the thread regarding what was involved to swap those.
Thanks in advance,
  • moto2000
Posted August 14, 2007 - 07:53 PM
This is a 2001 YZ426 with '03-'05 YZ bodywork, but you should be able to do the same thing with your WR.
  • hozhead
Posted August 14, 2007 - 08:05 PM
So did you need to swap the subframe to make that happen.
And is that a 450 tank? Yes, I know its not stock but is it for a 450 specifically.
  • moto2000
Posted August 14, 2007 - 08:26 PM
It's a YZ 450 3.3 gal (or whatever) IMS tank ...... the subframe and airbox are also 03-05 250/450 YZ parts. Pretty much a bolt on. Just need to make brackets for the tank mount and trim the upper subframe mount of the frame.
There should be alot of info in the YZ forum
